04-06-2012, 03:38 PM | #1 |
cuting coils
Is there a rule of thump cuting front coils .
Posted via Mobile Device |
04-06-2012, 04:16 PM | #2 |
Re: cuting coils
Rough rule of thumb is one full coil = 2" drop
____________________________ |
04-06-2012, 04:29 PM | #3 |
Re: cuting coils
Sweet I wasnt to sure I had it in my head it was one turn per inch. Thanks for the help
04-06-2012, 07:54 PM | #4 |
Re: cuting coils
1 coil = approx 2" of drop depending on the spring. Some = 2", others 3". It also slightly increases the spring 'rate' vs @ stock height but not enough to compensate for the amount of drop in some cases.
04-07-2012, 02:49 PM | #5 |
Re: cuting coils
rule f thumb is dont cut off thumb or any other fingers for that matter
04-07-2012, 02:55 PM | #6 |
Re: cuting coils
This...
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
04-07-2012, 08:16 PM | #7 |
Re: cuting coils
It's not truly your truck until it makes you bleed.
