04-06-2012, 05:08 PM | #1 |
Modifying the AC box
On my 76 blazer, I no longer have working AC and was looking for some ideas as to how to modify the AC box on the firewall to make it smaller but still look decent. I know that swapping out the parts for the factory non-ac assembly and modifying the firewall to match it would probably be the cleanest way to do it but, I would like to try to make what I have work first.
ac non-AC
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
04-06-2012, 06:12 PM | #2 |
Re: Modifying the AC box
Not sure about your question, Also, is that a grider with a wire brush? Thanks.
Posted via Mobile Device |
04-06-2012, 08:23 PM | #4 |
Ive seen guys remove the evaporator core and trim the box flush with the fan mounting surface with fiberglass so they could still use the heater. Its a much cleaner look, dont have any pics thou.
John 82 Chevy Silverado 350ci/TH350 |
04-07-2012, 05:49 AM | #5 |
I think the 88-98 trucks had all the stuff under the dash you might get away with rigging that up and smoothing out the firewall on that side.
04-07-2012, 08:33 AM | #6 |
78K & 79C Jimmys
on my AC dead trucks i rip what i can out
but in the winter I do use the AC "high" setting on heat to warm up the cab quicker so plumbing,and anything outside front of the air box goes
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-07-2012, 09:21 AM | #7 | |
I am thinking along the lines of what Jknight and motornut said, a clean way to cut off all of the heater box that I no longer need.
04-07-2012, 11:35 AM | #8 |
I just finished doing mine last night. It needs a final light sanding and then paint. It was a job. I have done it a little along over the last month in the evenings. You need to have a little experience with fiberglassing to make a good go of it. My box was half plastic and half fiberglass as removed from the truck. I created the basic structure of it using punched sheet metal from Lowes to that is used in framing roof trusses. The blower side was plastic, so one of the angled sections was heated and straightened. There was more labor involved than the $200 that is charged for aftermarket ones that delete the evaporater, but I have the satisfaction of having done it.
It will use the existing holes in the firewall, but a new one new hole will have to be drilled on the top left corner of the box above and to the right of the heater core lines. Last edited by 68 D88; 04-07-2012 at 11:40 AM. |
04-07-2012, 03:05 PM | #9 |
That is slick..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
04-07-2012, 05:33 PM | #10 |
vintage air unit will put it all in the dash
04-07-2012, 09:49 PM | #11 |
Wow that excellent how did you get the fiberglass to look so perfect and smooth
04-07-2012, 09:55 PM | #12 |
There is a company that makes ac delete boxes that look good I will post a link when I find them
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
04-08-2012, 07:13 AM | #13 |
I think you mean http://www.acdelete.com/pages/73-90_Truck.htm
04-08-2012, 08:19 AM | #14 | |
78K & 79C Jimmys
04-08-2012, 01:18 PM | #15 |
Thanks for the comments. I was able to get it so smooth on the exterior with a lot of determination and persistance - sand-glass-sand-glass-etc. If you have the money to spend, I'd recommend the one in the link provided, as it is well worth the $159.95 + $24.95 S/H. I have quite a bit of time tied up in mine, but enjoy a challenge from time to time.
07-25-2012, 09:47 PM | #16 |
As "fun" as this was to make, I've about talked myself out of using it after this brutally humid and hot summer in middle Georgia. I'm probably going with a vintage air unit after I get this truck back up and running. Funny how plans change.
07-25-2012, 10:16 PM | #17 |
The one you made looks 10 times nicer than the $159 buck one. I wish you could make me one lol.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
