![]() Join Date: Aug 2010
fully restored C-10 on Ebay - not mine
Pretty sweet little number if you ask me. Costly yes, but not near what it cost to do. Less than 1 hour to go, sorry.
http://cgi.ebay.com/ebaymotors/ws/eB...NA:MOTORS:1123 |
![]() Join Date: Feb 2010
Re: fully restored C-10 on Ebay - not mine
I seen that one. Very nice. Not to far from me. Little pricey.
![]() Join Date: Sep 2011
Since you're our resident expert, OEM. How would you rate this resto on a 1-10 scale? Understanding that you only have limited pictures to base your rating on.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
Nice truck, makes me wonder what a BBW AC PW PS PB truck would bring in similar condition. I don't know if you could build one for 21k in this shape but I don't think I would have restored a plain janer like this myself.
Just from pics I'd say 9 to 10. Seller stated $45 K invested the first time around and I believe it. Sold for $21K - that's a pretty good deal if you were looking for a turn-key truck. I personally think the 6cyl/3spd plain-janes have an appeal of thier own. Not all trucks need a V8, big window, and A/C.
#6 | |
#7 | |
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#8 | |
#11 | |
Couldn't have been better said! I've got a '66 deluxe, bbw, short/fleet and understand the appeal of those, but the base level, low option trucks are very neat in their own sense. This truck is very similar to the '65 I restored, and I loved everything about that truck. I too would give it a 9/10 rating, since they didn't re-gap the panels (though it's more "correct" as it is, I can't stand not doing it on a full-tilt resto like this), and the seat cover doesn't have the heat-sealed/embossed pattern in it that the base level seats had. I know '65s had the pattern in the vinyl seat, maybe '66 didn't? Underneath is very tidy, and the engine compartment looks very well detailed and correct, down to the GM heater hoses and tower radiator hose clamps. They got the sheen and color right on the fawn interior paint as well. The dash isn't exactly the brown color it should be, but they tried atleast- that's often overlooked on a '66. I can't tell if they have the correct overspray pattern on the bellhousing, but that's to the point of nit-picking; this is a gorgeous truck and one I'd be very proud to own.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#13 |
Thanks for posting that BJ '66 step Ron.
What's your take on these comments: Details: This is a very rare 1966 Stepside as it has a 305cid V6 engine that was used in GMC medium duty trucks. It also has optional power steering. Very rare also because it has 4-wheel drive. Very few 1/2 ton trucks were built with the 305cid V6 (one year only 1966). This is a very complete and detailed restoration. Am I missing something..?
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
#14 | |
p/s on 4 x 4s is a question though. was it optional from 60? if not when, what year?. any that I know off, have all had it added. I am going to check from a reliable source. it would be interesting though to find out the statistics on I6 vs V6 in GMC 4 x 4 s. they both have that bottom end pulling factor. the only benefit that I see with the I6 is that it would have about 200 lbs less over the frt axle ron |
#15 | |
66 had the embossing but 65 did not. |
#16 |
I know that the deluxe seats in '66 had the white stripe embossed/heat sealed on, and had some other heat-embossed stripes that '65 didn't have. What about the standard seats though? The '65 I restored came with the standard seat, and had the build sheet still under it so I know it was the original seat. It had a vinyl cover that had a pattern embossed into it. Did the '66 standard seats also have an embossed pattern on the vinyle covers?
Here's a clipping from the '65s original seat cover. ![]()
#17 |
The pattern for a standard '66 consists of simple straight lines and pebbly grain. You can kind of see it below.
#18 | |
"Ron, this is Lewis. I just checked my popular parts catalor X164003, printed May, 1964 and found no power steering offered for any K-series truck 1000-2500. I also checked parts manual X166001 printer Oct. 1967, with the same results. It seems like the J-series (1962) was the first year power steering was offered on a GMC, from what X164003 has to say. It is possible that a dealer installed unit could have been put on K-series trucks, but as you know, the cylinder and brackets would have to be entirely different than for a 2WD truck. As far as engine preference, the only engine with comparable torque to the 305 would have been the CHEV. 292, and that wasn't available in the 1000 series trucks. In the US, a Chev. engine wasn't available in any GMC until 1964, as you are aware of, Ron. I hope that this will shed some light on the questions you asked. As a side note, one can install a '69-later intrigal p/s gear sector with the approiate spacer plate to shim the gear away from the frame." ron |
#19 | |
http://www.barrett-jackson.com/appli...&aid=443&pop=0 ![]()
#20 | |
But I gotta add, the Big Vee's ...when they are in their element, stand pretty tall as a true big block. I've owned a couple 292's over the years...and I loved them...but these BBV6's just kick a$$. I put a Q-Jet on my 351E a while back....and that coupled with twice pipes and an HEI make that thing go like a scalded cat...even at 7K lbs. BTW...I sure had manual steering on my K1000 when I got it...and come to think of it....can't say I've ever seen the OE p-steering on a K series GMC of this vintage....though it probably existed. I'm gonna throw it up on Jollys site and hear what those folks have to say on it. Pete Chronis...GMC guru from NorCal will have the story....I'll paste his comments when I get 'em.
#21 | |
Hollister, CA.
![]() Join Date: Sep 2006
Power windows were an option ? Posted via Mobile Device
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#22 |
Yer killin me....Chief.
#23 | |
ron |
#24 |
Rodger on L.E.Matkin knowin his $hit.....He's definately a wealth of knowledge.
#25 |
Hollister, CA.
