Old 04-06-2012, 10:58 PM   #1
79 blue monster
79 blue monster's Avatar
drop question
how much drop do i get from a rear axle flip while keeping my stock leafs? i want to keep it a 3/4 ton leaf pack but get a 6in drop in the back. do i need to buy drop shackles? also wut is the angle that my drive shaft needs to be to weld my axle plates(perches) on?
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
Old 04-06-2012, 11:48 PM   #2
oldschool18
oldschool18's Avatar
Re: drop question
i would flip the axel and see what drop you get with the 3/4 leafs i think theres more leafs so i'm guessing at least 4" and just try to keep the drive shaft straight
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 04-06-2012, 11:58 PM   #3
76Charlie
76Charlie's Avatar
Re: drop question
Rock on, I started when I was 15, 3 years ago. You'll be surprised how much you'll learn from these cool trucks. Try some drop spindles
1976 GMC SIERRA CLASSIC CAMPER SPECIAL! 454 BIG BLOCK BABY!
76Charlie is offline   Reply With Quote
Old 04-07-2012, 08:39 AM   #4
79 blue monster
Re: drop question
when you say keep the driveshaft sright, what do you mean? i cant have it perfectly inline with the axle, because it will vibrate.
Old 04-07-2012, 08:41 AM   #5
79 blue monster
Re: drop question
yeah haha i love these trucks, i always wanted a 67-72 body style, but now that i have a square, i know i made the right choice.
Old 04-07-2012, 11:05 AM   #6
J Knight
J Knight's Avatar
Re: drop question
If you want to know exactly how much drop you get from an axle flip without removing any leafs you need to measure from the bottom of the axle tube to the top of the leaf spring then add 1/2 to 3/4 in to the measurement for the flip bracket. This will give you your exact drop, also measure the distance from the top of the spring to the bottom of the frame rail, then measure the axle tube diameter, add 1/2 to 3/4 in for the bracket, deduct this measurement from the spring to frame measurement and this will give you your suspension travel room. If you have less than 2in I would recommend a c-notch.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-07-2012, 11:28 AM   #7
SCOTI
SCOTI's Avatar
Re: drop question
On a 3/4 ton, flipping the rear would get around 7" of drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-07-2012, 07:25 PM   #8
oldschool18
Re: drop question
my c-10 was bagged and the driveshaft was pretty straight and never vibrated
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 04-07-2012, 09:08 PM   #9
JCampbell
Re: drop question
I got 8" out of the flip on my 1-ton.
JCampbell is offline   Reply With Quote
Old 04-07-2012, 10:40 PM   #10
79 blue monster
Re: drop question
oh, so it wont matter what angle my drive shaft is
Old 04-07-2012, 11:04 PM   #11
SCOTI
SCOTI's Avatar
Re: drop question
It definitely can/does matter. One might have an issue; another may not.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-08-2012, 05:39 AM   #12
Square_78
Square_78's Avatar
Re: drop question
I had 3/4 ton springs in the back of mine and my back end came down 8.5" with a flip kit. I did remove a couple leafs though. I now have 4 plus the overload. My driveshaft was making al sorts of terrible banging noises after I dropped it. Had to install 4 degree shims but I should have used more. Still vibrates at low speed.
Square_78 is offline   Reply With Quote
Old 04-08-2012, 09:12 AM   #13
79 blue monster
Re: drop question
well i dont really know now lol, so far i have answers of 7in, 8in, or 8.5in? i guess i'll have to measure and get a reading.
Old 04-08-2012, 02:11 PM   #14
SCOTI
SCOTI's Avatar
Re: drop question
Exactly, you need to measure to get an accurate answer. Add 1/2 the diameter of the axle tube to the height of the spring pack & you'll be very close to the amount of drop.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-08-2012, 11:42 PM   #15
79 blue monster
Re: drop question
just did and its gonna be 7in of drop. do i need to go 5in of drop in the front then for it to sit level?
Old 04-09-2012, 12:43 AM   #16
SCOTI
SCOTI's Avatar
Re: drop question
What's the difference in the F to R height now?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-09-2012, 11:08 PM   #17
79 blue monster
Re: drop question
I didnt measure yet, but i'll update tommarow with measurements.
