Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-06-2012, 11:33 PM   #1
Dragun12
Dragun12's Avatar
turbocharging?
i know this sounds totally crazy but could turbocharging an engine help with fuel economy?
Dragun12 is offline   Reply With Quote
Old 04-06-2012, 11:41 PM   #2
late68
late68's Avatar
Re: turbocharging?
IMO it makes it worse...
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline   Reply With Quote
Old 04-06-2012, 11:46 PM   #3
Dragun12
Dragun12's Avatar
Re: turbocharging?
well ya if you use a big carb or injectors but what if you used it with a small carb i do alot of freeway driving
Old 04-07-2012, 01:15 AM   #4
late68
late68's Avatar
Re: turbocharging?
Fact of the matter is the"forced induction" aspect of the situation. I know alot of the newer cars are moving towards the turbo, but it comes with the technology. I used to have a 4 cyl turbo engine and couldnt get past 18 mpg on the highway.
Old 04-07-2012, 03:07 AM   #5
Dragun12
Dragun12's Avatar
Re: turbocharging?
what did you do to it?!
Old 04-07-2012, 09:58 AM   #6
longbed67
longbed67's Avatar
Re: turbocharging?
IF you can keep your foot out of it and you have it tuned right (not small carb/ big carb) AND have the properly sized turbo (both turbine and compressor size) you will get better economy cruising as the volumetric efficiency of the engine increases.
The guys at www.theturboforums.com are of great help and there is a TON of info there that will answer just about any question you have about turbocharging.... If your a newb when it comes to building a turbo setup I would suggest a good 40-60 hours of research and studying before even considering it
Which engine are you considering putting a turbo on?
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-07-2012, 08:21 PM   #7
Dragun12
Dragun12's Avatar
Re: turbocharging?
sweet so it so posible thanks longbed67
