Old 05-07-2003, 08:50 AM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
C-Notch
Has anybody done a 6 inch rear drop without doing a c-notch. Looking under my Blazer last night and there doesn't look like there is enough room. If you did use one, bolt in or weld. If I have to put on on I will have to do it with the body on. I cant just take the bed off like you truck guys. Any help would be appreciated.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 05-07-2003, 10:28 AM   #2
XXL
Seņor Member
XXL's Avatar
The CPP C-notch kit can be installed with the bed/body in place.
XXL is offline   Reply With Quote
Old 05-07-2003, 03:25 PM   #3
Frank_Zeller
Frank_Zeller's Avatar
Yep........there is about 2 inches of travel before you hit the bump stop. I cut the bump stop off level with the frame per ECE The U bolt hit the bump before the axial hits the frame. Planed on a C-notch someday.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 05-07-2003, 07:54 PM   #4
baggedblaz
my burb has a 6in rear and its about 1 and 3/4 away from the frame it bottoms out but not too much at all only on big potholes or if you go fast over bumps.
the roads out here suck for lowered trucks! but i plan to notch it it rides alot better with a load it preloads the rear spring and actually doesn't bottom out as much. you could do the bolt in relatively easy with the body on just need a good drill and a sawzall or a plasma ?
the blazer might be a better candidate for the 6 because of the weight ?
'82 chev swb 4dr 2wd project
'72 2wd blazer LT1/4L60E "SURFSIN" bagged 20's
'71 2wd blazer
'95 chev 2wd Xcab swb
baggedblaz is offline   Reply With Quote
Old 05-07-2003, 08:05 PM   #5
Alexis
Member since 2000
Alexis's Avatar
I got a 4/6 and didn't C-notch, even had the exhaust hang below the frame and didn't have much trouble with that.
Alexis is offline   Reply With Quote
