04-07-2012, 11:16 AM | #1 |
68 c10 5.3 4l60
Well got my swap done except a little bogging issue i have boiled down to a tuning prob I will call my tuner on Monday
Posted via Mobile Device |
04-07-2012, 12:00 PM | #2 |
meowMEOWmeowMEOW
Re: 68 c10 5.3 4l60
ammo can hold ecu i assume? pretty cool
all the ammo cans in my truck just hold....ammo.
04-07-2012, 02:07 PM | #3 |
Re: 68 c10 5.3 4l60
Looks nice! I have the same ammo can, I keep my junk yard tools in it. Never thought of putting a PCM in it, cool idea though.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-07-2012, 04:09 PM | #4 |
Garage wrench
Re: 68 c10 5.3 4l60
that looks like an awesome truck. Anymore details on it?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
04-07-2012, 05:59 PM | #5 |
Re: 68 c10 5.3 4l60
I bought the truck about a year ago all original. Drove it home install a drop and disc brakes and the wheels and drove it daily with the 250 3 speed until about 2 months ago when i ran across a deal on the 5.3. I did the door logos myself with some homemade stencils . Soon as i get my tuning situation figured out it will be my dd again.
04-08-2012, 08:42 PM | #6 |
Re: 68 c10 5.3 4l60
Can we get more info on the wheel/tire setup, and what drop?
That thing looks great. I even like the smoothed stock VC's. I was gonna do that on mine, but ended up getting different ones instead. Also, where did you mount the coil packs?
04-08-2012, 09:00 PM | #7 |
Re: 68 c10 5.3 4l60
what are you using for a throttle body spacer?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
04-08-2012, 10:08 PM | #8 |
Re: 68 c10 5.3 4l60
Truck has cpp 2 1/2 spindals with just over one round cut fromnfactory coils.rear is cpp 5" coils 18x8 18x9.5 338's 255/40 285/50 nitto tires. Coils are mounted on rear of heads on homemade brackets,plugwires rout behind headers and up to coils.tb spacer is a poweraid i had laying around from another truck it just helped me get throttle linkage away from truck water pump using ls1 intake.
04-09-2012, 06:41 PM | #9 |
Re: 68 c10 5.3 4l60
Well figured out what the bogging was. I had the o2 harness reversed.now it runs perfect.
04-10-2012, 08:04 AM | #10 |
Re: 68 c10 5.3 4l60
Great looking truck! Glad you got it fixed and running right.
04-10-2012, 12:50 PM | #11 |
Re: 68 c10 5.3 4l60
What did you do to your intake? I sure like it what ever ya did.
04-10-2012, 02:21 PM | #12 |
Re: 68 c10 5.3 4l60
Nothing more than some "cast iron" paint. its from a ls1
04-19-2012, 02:05 AM | #13 |
Re: 68 c10 5.3 4l60
What motor mounts are you running and what kind of headers are those? Also, did you move the engine forward or back? I'm wanting to do the ls swap in my 72 but am confused on what position to put the motor in.
1987 gmc sierra v1500. 350 tbi, 700r4, 6" sky jacker lift, 15" Mickey Thompson wheels, and 35" bf Goodrich km2 tires. |
04-19-2012, 09:59 AM | #14 |
Re: 68 c10 5.3 4l60
just heard of another recent swap that was having issues. they took it to a local shop and it was this same issue.
66 LWB/BBW work in progress 68 Camaro SS bigger work in progress 95 Roadmaster Wagon 12.36 @ 107.74 99 Hayabusa 8.72 @ 162 00 Hayabusa 9.33 @ 153 |
04-19-2012, 08:59 PM | #15 |
Re: 68 c10 5.3 4l60
I am using my 6 cyl mounts and stands. I made my own adapter plates with some 1/4" steel bolted them to my block droped it in and traced my mounts holes onto the plate when it whas where i wanted it to sit pulled it back out drilled and tapped holes for my mounts to bolt to the plates. My prob sits a little further forward than most because my coilpacks are on the rear of my heads and i needed room for them and my throttle pedal rod.headers are dynatech 2nd gen camaro .
04-19-2012, 11:40 PM | #16 |
A guy with a truck
Re: 68 c10 5.3 4l60
Nice! Do your headers hang below the framerails?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-20-2012, 07:09 AM | #17 |
Re: 68 c10 5.3 4l60
Yes they hang below but no more than my truck oil pan.
04-20-2012, 12:32 PM | #18 |
Re: 68 c10 5.3 4l60
Did you have to notch the factory cross memeber for the truck pan to work?
04-20-2012, 05:48 PM | #19 |
Re: 68 c10 5.3 4l60
Nope its close but its just above the sway bar and cross member
02-26-2013, 08:09 PM | #20 |
Re: 68 c10 5.3 4l60
Any mods to engine? How's the gas mileage?
03-03-2013, 11:18 AM | #21 |
Re: 68 c10 5.3 4l60
It has a car intake ,comp cam and tune. I honestly dont know about mpg. I just drive and enjoy it. My daily commute it stop and go backroads .
03-12-2013, 01:12 PM | #22 |
Re: 68 c10 5.3 4l60
What all did u have to do to put the car intake on. Ive been told u need to change the water pump and some other things?
03-12-2013, 06:58 PM | #23 |
Re: 68 c10 5.3 4l60
Car intake was easy. I have a truck water pump, the upper fitting is a press fit so i put some heat on it with a torch and turned the neck a little to clear the throttle body linkage. I have a f-body alt setup and now i have f-body power steering pump with some spacers i got at ace to make them inline with the truck belt line.
