Old 04-07-2012, 03:49 PM   #1
FLDBRED
Quick Stab???
After I replaced the intake manifold and carb on my 71 with a 307 smallblock, I can't get rid of stumble when you give it a quick stab of the throttle. If you accelerate at a steady pace it doesn't stumble and feels crisp, stab it and it wants to die! Any ideas? Thanks!
FLDBRED is offline   Reply With Quote
Old 04-07-2012, 03:52 PM   #2
Stevo427
Re: Quick Stab???
When my truck did that it was the accelerator pump diaphragm
Stevo427 is offline   Reply With Quote
Old 04-07-2012, 04:21 PM   #3
FLDBRED
Re: Quick Stab???
Thanks I'll take a look at that? This is a Holley 600!
Old 04-07-2012, 04:35 PM   #4
Stevo427
Re: Quick Stab???
Mine was to. Although mine was a 650
Old 04-08-2012, 08:36 AM   #5
FLDBRED
Re: Quick Stab???
Is there a way to check to see if the accelerator pump is good?
Would a bad vacuum advance cause this problem?
Old 04-08-2012, 10:26 AM   #6
old Chevy guy
old Chevy guy's Avatar
Re: Quick Stab???
If you look down the throat of the carb,truck not running, and pull back on the throttle you should see it spray. and yes bad vacum advance could do that also.
old Chevy guy is offline   Reply With Quote
Old 04-08-2012, 10:50 AM   #7
FLDBRED
Re: Quick Stab???
Thank You!
Old 04-08-2012, 08:17 PM   #8
old Chevy guy
Re: Quick Stab???
Did you find the problem?
Old 04-09-2012, 03:14 PM   #9
FLDBRED
Re: Quick Stab???
Not yet, it is getting a shot of gas! ?
Old 04-09-2012, 03:32 PM   #10
CC69Rat
CC69Rat's Avatar
Re: Quick Stab???
How many miles are on the engine? Could be a slack timing chain. (let's hope not)
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-09-2012, 03:33 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Quick Stab???
The holley 600cfm (1850) carbs have a dischrage nozzle (squirter) located inside the choke horn. It's held in by a big phillips head screw. You can remove it and put a largert squirter in there to give you more "pump shot". There will be a number stamped on the squirter. You will have to remove it to see the number. Whatever the number is... always go up or down a minimum of 3 numbers to get any effect from the change.
Larger number... more pump shot. Lower number... less pump shot.
If it has the original discharge nozzle (squirter)... it should be a #31. Try a #34 and see what that gets ya.
Also... what vacuum does the engine pull at idle. If it's an automatic... take the vac reading with the engine in gear with the brake on. That way we can determine what power valve you will need as well.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-10-2012, 06:36 PM   #12
FLDBRED
Re: Quick Stab???
When I got home from work, I took a flashlight and looked closely, it seems that no fuel is coming from that nozzle. In fact, the arm to the accelerator pump barely moves no matter how I adjust it, and I can't really move it manually. Should I replace the diaphragm? Thanks... it's been decades since I worked on carbs!
Old 04-10-2012, 09:07 PM   #13
GASoline71
GASoline71's Avatar
Re: Quick Stab???
Gary
Old 04-14-2012, 05:16 PM   #14
FLDBRED
Re: Quick Stab???
Well...I guess it's time for a new carb! I was going to order the parts for the accelerator pump, but before I took the carb off, I turned the idle mixture screws all the way in, the truck kept running, so I guess the power valve is shot! That's what you get when you buy a used carb. Instead of messing around and taking the carb on/off, I guess I should just buy a new one! Any suggestions on which one? Thanks for all the help!
Old 04-14-2012, 09:26 PM   #15
GASoline71
GASoline71's Avatar
Re: Quick Stab???
You only need a new power valve. Or you have a wicked vacuum leak from somewhere else. Unless you are looking for a reason to buy a new carb... but a new power valve can be changed in half an hour.
What manifold do you have it mounted on?
Gary
Old 04-15-2012, 08:45 AM   #16
FLDBRED
Re: Quick Stab???
The reason I thought about getting a new carb was because, it looks like in "addition too" the accelerator pump, the power valve is also bad! The carb 80457s looked brand new when I bought it, but every adjustment was way off!
Do you think I should just rebuild it?
The intake manifold is an Edlebrock Performer.
Thanks!
Old 04-15-2012, 09:52 AM   #17
neverending
Re: Quick Stab???
cant say i have messed with 600's much but do the have an adjustable cam that can be turned to trigger pump faster when throttle is pushed ? mite even make sure vac advance is hooked to ported vac and not manifold .
neverending is offline   Reply With Quote
Old 04-15-2012, 02:09 PM   #18
FLDBRED
Re: Quick Stab???
THANKS EVERYONE! I replaced the power valve and accelerator pump diaphragm and now it runs like a big block! LOL. It only took a half hour and sure beats buying a new carb, again thanks for everyone's help!
Old 04-15-2012, 03:18 PM   #19
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Re: Quick Stab???
That video was very informative. Thanks!
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 04-15-2012, 04:00 PM   #20
GASoline71
GASoline71's Avatar
Re: Quick Stab???
Way cool dude! Glad you got it sorted out. Got your PM as well!
Good job!
Gary
