Old 04-07-2012, 07:05 PM   #1
owner 84
owner 84's Avatar
Body mounting kits
Hi guys,
I'm sorry If you have had this question before, but I'm really wondering about the best body mounts to buy for my 1978 GMC/ fleetside c3500.
I have heard bad things about LMC's body mounts, but has anyone tried them?
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=35
I have also heard bad thing about prothane
http://www.suspensionconnection.com/...7-102-gmc.html
Energy Suspension - Body Mount Set
http://www.oreillyauto.com/site/c/de...4038&ppt=C0329
I don't feel comfortable because nobody, who I know, has used them. I said you may have the right idea or choice to pick one good mounts.
I prefer the original one (OEM) has the GM stamp on, but where to find them?
Please tell me what good/bad, and where to fine OEM if possible.
Thank you guys,
Nasser
email me @ nasser_060@hotmail.com
and Check out my flicker @
http://www.flickr.com/photos/0060/
owner 84 is offline   Reply With Quote
Old 04-07-2012, 07:48 PM   #2
Telecasterjoey
Re: Body mounting kits
I ordered Rad support mounts from lmc, no issues.
Telecasterjoey is offline   Reply With Quote
Old 04-07-2012, 09:08 PM   #3
badpontiacs
badpontiacs's Avatar
I have LMC's mount kit, no problems here. I have a big inch big block and haven't had any problems.
badpontiacs is offline   Reply With Quote
Old 04-07-2012, 09:57 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Trust in energy suspension they know what they are doing when it comes to these things
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-09-2012, 05:34 PM   #5
owner 84
owner 84's Avatar
That's great guys.
BUT is the OEM one available or not?
Old 04-09-2012, 07:00 PM   #6
Jonboy
Slots go on anything!
I used the complete LMC kit on my '74. I had to space up the bushings on the radiator support, but they mounts themselves worked fine. A trip to Home Depot for some large fender washers, and the problem was solved.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-10-2012, 02:05 PM   #7
owner 84
owner 84's Avatar
seems that LMC has the best mounts, has not it?
Old 04-11-2012, 08:43 PM   #8
Axle
Axle's Avatar
I've got the energy suspension body mount kit in my truck. (and two cars). No complaints.
Alex.
Axle is offline   Reply With Quote
Old 04-11-2012, 11:18 PM   #9
owner 84
owner 84's Avatar
Alex.
you are the only one recommends energy suspension body mount kit. Does it last longer than 10 years or more?
Old 04-12-2012, 01:06 AM   #10
INSIDIOUS '86
I recommend energy suspension as well. And so does rob on the make it handle thread
They urethane are a lot more resistant to age and road cantaminants than rubbers are so they should last lOnger
Old 04-12-2012, 09:59 AM   #11
Jonboy
don't you have to reuse your bolts and brackets for the ES kit? (i.e., it replaces the rubber part only?) Mine had turned to powder, so the LMC kit was a great alternative.
Old 04-12-2012, 06:46 PM   #12
Deaol
I used the Prothane body mount/rad mount and rad cushion kit. Was cheap and worked very well. Over 100k on it.. no squeaks.. hasn't been a harder ride as some say with urethane.
got it from http://www.prothanesuspensionparts.com/
ordered and on my door step in 2 days.
* 1968 GMC Swb - 98% done (current restoration)
* 1971 Chevy Lwb - Retired Dump Hauler
* 1982 K10 Longbox - New Dump Hauler
Deaol is offline   Reply With Quote
Old 04-12-2012, 06:58 PM   #13
Axle
Axle's Avatar
They're polyurethane, should last longer than rubber bushings. I've got an Energy Suspension set in my nova since about 1988/1989. No splitting yet. Looking at my records, my truck got them in May 2005, still look the same as the day they went in.
don't you have to reuse your bolts and [x] for the ES kit? (i.e., it replaces the rubber part only?)
Correct, it is only replacement bushings. No washers, no bolts. On the 83 cab style they are 4 identical 1/2-20 bolts anyway (4" or 6" long, didn't measure as I reused them). I did have to buy 1 new cup washer at the dealer (was around $5).
LMC should offer a poly kit with hardware, they'd probably sell more of 'em. (me for instance, I don't want rubber replacements, but sometimes you also need the hardware, kinda nice to just get everything in one box).
Alex.
Old 04-12-2012, 07:05 PM   #14
Pro Performance
Pro Performance's Avatar
The Prothane is a good kit, and priced right. I personally ran the Prothane on my 84 C10, and worked great. Just make sure you use the grease supplied.
We are direct with Prothane, so let me know if I can help you out.
Pro Performance is offline   Reply With Quote
Old 04-12-2012, 07:45 PM   #15
Axle
Axle's Avatar
I've never greased a body bushing. If they are squeeking, the bolts are too loose. =-)
I havn't looked yet, but does prothane have a bushing kit for the 88-91 Crown Vic/Grand Marquis?
Alex.
Old 04-12-2012, 10:46 PM   #16
JPalmer81
JPalmer81's Avatar
Good thread. I am wanting to do the same to my crew cab, does the LMC kit have all the hardware including cup washers and bolts? And is the LMC kit all rubber?
1988 Chevy Crew Cab 1ton 4x4 SRW LWB
1977 Dodge 1 ton 4x4
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=516872
"The price of Freedom is Eternal Vigilance"
JPalmer81 is offline   Reply With Quote
Old 04-14-2012, 12:41 PM   #17
owner 84
owner 84's Avatar
I guess so, but should any one tried LMC kits post some pics to make it clear what comes in that box?
Old 04-14-2012, 12:45 PM   #18
owner 84
owner 84's Avatar
I am confusing about what I buy. I hate this feeling. I guess sometimes I don't have to think just go and do it. However, asking is a good way to avoid making mistakes and saving time and money.
Old 04-15-2012, 02:12 AM   #19
andrewmp6
Also look at http://www.brotherstrucks.com/ see if they sell the same kit it might be cheaper.But either way i trust brothers and lmc.
andrewmp6 is offline   Reply With Quote
Old 04-15-2012, 02:00 PM   #20
bilfman
bilfman's Avatar
I believe you are over thinking the body mount issue. Kits made today are superior to the ones made 25 to 30 years ago. The poly kits are stiffer then the rubber, though the poly kits add more support. Over the years I have ordered from LMC, dealer and a local aftemarket parts store and have never said " damm those suck". So just order a kit from wherever you want an I am positive you will appreciate whatever you get. However I would recommend ordering a new bolt kit with it.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-15-2012, 03:21 PM   #21
owner 84
owner 84's Avatar
Smile Re: Body mounting kits
I have more positive feeling toward LMC kits because they are specified on trucks. They also offer bolts and all hardwares needed although their price is high. I hope they last longer than I expect .
Old 04-16-2012, 12:43 AM   #22
manimal
manimal's Avatar
I have used Prothane on all my Chevy trucks. Keeps the body lines straight and they dont wear out like OEM rubber.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 04-16-2012, 11:29 AM   #23
owner 84
owner 84's Avatar
sounds good
Old 04-19-2012, 07:11 AM   #24
DetroitDan
DetroitDan's Avatar
put me down for one vote for rubber. I installed a set of urethane on a 79, it made the truck ride terrible, I could feel every single crack in the pavement. Honestly it was like bolting the body directly to the frame, steel to steel. I took it out after two weeks to put oem rubber in, and found one of the two front ones under the radiator had already split. It's facotry rubber for me, from here on out. Nothing like driving an old truck that still rides like new
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 04-19-2012, 08:59 PM   #25
Axle
Axle's Avatar
I didn't notice a difference. But then, I've got the 7 leaf spring pack in my truck and the hd 1 ton springs up front. =-)
Alex.
