Old 04-07-2012, 08:01 PM   #1
diabloceto
Gas Gauge help
okay I replaced my sending unit in the tank today. I hooked the wire to it and turned the key it read 3/4 of a tank I was like sweet it works no more tracking mileage. So I turned off the key unhooked the wire and put the hoses on and the small clip that holds the gas lines up. Put the seat back in, turn the key and now the gauge stopped working. When I ground the wire that goes to the sender it goes empty when I leave it open it goes past full to like the 3 o'clock position. Anyone have any ideas, I would much appreciate it.
diabloceto is offline   Reply With Quote
Old 04-08-2012, 02:20 PM   #2
diabloceto
Re: Gas Gauge help
Anyone?
Old 04-08-2012, 02:34 PM   #3
cdowns
cdowns's Avatar
Re: Gas Gauge help
i've always liked running a ground wire from the sending unit to the cab// no it is not stock but i have found it wort my time
Old 04-08-2012, 02:40 PM   #4
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Gas Gauge help
http://www.chevelles.com/techref/tecref18.html
Zoomin is offline   Reply With Quote
Old 04-08-2012, 02:41 PM   #5
diabloceto
Re: Gas Gauge help
Where would you hook that up at under that bolt that is in the lug you plug the wire into?
