Location: Hickory, NC native, but stuck in Valdosta, Ga
Positive Traction
What are the Pros and Cons? I know what I want to do, but just need to understand why?
Canadian Trucker
Re: Positive Traction
I don't see any negatives to positive traction. With a posi or limited slip you get power going to both wheels when you need it, but during turns it still allows the wheels to move at slightly different speeds. If you get into a situation where one wheel slips the other will get power to get you out. You might lose some fuel economy (might being the operative word here) but thats the only con I can see. There are different types of Posi units you can get, but I've found that the best bang for buck is an Auburn limited slip.
![]() 2020 Silverado Trail Boss - 6.2/10spd |
I know the pieces fit
Why auburn over eaton? Just curious. To the op, the only downside I know of is purchase price and installation cost. While the rear end is torn apart its a good time to change the ring and pinion if you're thinking of a different rear gear ratio.
Canadian Trucker
I've had good luck with Auburn, plus price wise the Auburn is cheaper. And if Eaton really wanted to make money, they'd talk GM into the True Track rather then the Gov bomb they supply know.
There is another drawback that hasn't been mentioned yet. If you're in an area that you're likely to lose traction, like snow and ice conditions, a posi trac is more likely to spin out on you. If you give it too much gas, an open differential will break traction on only one tire, the other will still grip and often keep you from sliding out. A posi or a locker will spin and break traction on both tires, causing the rear end to slide out.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
#6 | |
Ie going sideways from a stop= low momentum an better time to react to the situation vs a open diff were it spins out during cornering at high momentum and you get surprised with very little time to react Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
There are many things to consider when choosing to modify your differential. I'll explain the basics on then and give some pros and cons. Ultimately it should be based on vehicle usage to make your decision.
Firstly differential basics, the 2 main reasons for a differential is 1. to get power to the tires and 2 to ease drivetrain stress when cornering(lets inside and outside tires turn at different speeds. Readers digest versions below... 1. open diff- only 1 tire recieves power at any given time pros-cheap, safe due to never breaking both tires loose. cons- only one wheel traction 2. Limited slip/posi trac- these use clutches to apply traction to both tires. pros- does enable 2 tires to have power, enables slippage when cornering, cluth packs allow differential to minimize stress when cornering. cons-clutch packs can burn out under heavy srtess, it does not allow a full 100% delivery to both tires, in high load situations (such as deep mud or side of hill) it will let the tire with the least amount of resistance spin, not both. Usually this is the tire that won't get you moving. ie if you are off road and have a wheel in the air, that is the one that will be spinning, so you are stuck Can be dangerous for losing control on slippery road conditions. 3. Locker. There are several types of lockers out there. But basically it is a true lock that lets both tires get 100% traction. Their design does still allow for slippage on a turn, you may hear a ratcheting sound from your diff when cornering, it is a normal part of their design. pros- excellent 2 wheel traction even if a wheel is in the air your other tire will turn, No clutches to wear out. cons- can hear some of them, not the best choice for a front differential (eaton Tru-Trac works in the front well though), can loose control on slippery roads, must learn to alter your driving habits on ice and snow. 4 Spool- is a full mechanical lock of the rear diff, allows for no side to side slippage at any time. Pros- 100% traction all the time, strong (really no parts to wear) cons- tires will always chip or stutter on a corner, never use in the front of a recreational 4x4. That is a basic rundown. I know that there is tons of more info to go to each, but I put what I did to be quick and to give Smoke_Dog a starting point for research. My personal preference is a locker, I have used them for 20+ years and love the improvement they offer.I have owned high hp muscle cars and extreme 4x4's and am happy with the units. I personally think a rear locker is the single best improvement for a 4x4, hands down. I live in Canada in a harsh winter area and love the additional traction, but there is a big BUT here for sure. These can be extremely dangerous on ice, you really have to know your vehicle and watch how you throttle. A little too much on the highway at 60 and it can be the tilt o' whirl ride. I currently run a tru-trac in my front dana 60 and a detroit locker in the dana 70 rear. Works great and would never look back. So if you are a 2wd pavement runner who wants to smoke 2 tires from time to time a limited slip is fine. If you to off road with your truck a bit, you can't beat a good locker. Best of luck on your research!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 Last edited by bilfman; 04-09-2012 at 12:53 AM. |
![]() Join Date: Jul 2010
Go with a powertrax..no gear set up & you can do it yaself
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#9 | |
I will agree that the TruTrac is a better design, I got one in my Chevelle that spends alots of time on road courses and I will never put anything else but a Tru Trac in a car that has to corner. I bet it would work great in a truck too, less likely to spin out like a locker or a friction style posi will.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." Last edited by 406 Q-ship; 04-09-2012 at 02:16 AM. |
With all this being said! Let's make it simple! I'm just going to drive the truck normal and just like the fact that I have it, if needed! So what should i do?
#11 | |
![]() Join Date: Apr 2009
I personally need more info on what kind of driving you do?
*Do you tow? *Do you have 4WD? *Do you like to do "Burnouts" *Is your current rear having issues or noises? *Can you afford a complete differential overhaul? This stuff gets pricey real quick, If your a daily driver, all road diving, I would say price up the swap Before you start tearing into the rear. You may fing you may Not need it after all. Desert PS: Hey "Bilfman" Great explanation of all options on rears. Last edited by Desert1957; 06-15-2012 at 11:15 PM. |
#13 | |
Just want it just in case I need it!!! The truck is just a driver and it looks good!!!!
#14 |
Going withe eaton!!! Will let U know How it went next week!!!
#15 |
Done ddeal went with 373's install complete Saturday
#16 |
Send smoke!
#17 |
#18 |
Feels a little different, but it hasn't been tested yet, because vaccum lines for engine, upgrades are not set up right! Bottom line is can't remember how things go!
#19 |
michanical lockers are not the way to go with a short wheel base. they will tend to lock and unlock when turning. when they lock on a corner you dont just hear it for feel it.
my truck dont turn well at all because its long i dont hear my locker inless the wheel it turned all the way like pulling into a parking spot. added bonis sounds like a pos and adds to the sleeper look lol if you wont limit slip this is the way to go http://www.off-roadweb.com/tech/1101.../photo_07.html ... there are no clutches so you dont have to add anything to the oil and you can use your brakes to control the power to both wheels i put a full spool in the front and a locker in the rear of my truck. i did this because i go mudding and do some truck pulling and its a daily driver, you wont wheel spin but not just 2 wheels. indiana has some bad winters and when i need to i lock 1 lockout and when i really need it ill lock both but not for long full spool in front is not verry streetable thats why i have lockouts insted of drive pucks
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
#20 |
I do a lot of road course in my truck. So I got a truetrac diff in mine with 373s and a 90's 30 spline axles and thick aluminum cover/stud girdle. I don't notice any difference in the way it drives other than it doesn't spin my right wheel all the time. I love the hell out of it. Well see how long it lasts. I'm good at exploiting the weak points in equipment
#21 |
78K & 79C Jimmys
my 79 has the "1G80" @3.4 ratio stock
but my 305 don't squeal em tires all the time lol but sure throws the dirt and it does doughnuts on snow/ice but i havn't been stuck yet
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#22 |
BAD BOW-Silverado XST
Would you rather leave a single long streak? Or two long streaks and launch sideways with enough power?
