Old 04-08-2012, 01:31 PM   #1
WEBBY1
WEBBY1's Avatar
lowering blocks
how are they? summit has them for a 4" drop for like 30 bucks?
WEBBY1 is offline   Reply With Quote
Old 04-08-2012, 01:38 PM   #2
tobytuttle
tobytuttle's Avatar
Smile Re: lowering blocks
What are you lowering?
tobytuttle is offline   Reply With Quote
Old 04-08-2012, 02:07 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: lowering blocks
4" blocks? Thats too much block on just about anything. What are you lowering?
Old 04-08-2012, 02:11 PM   #4
tobytuttle
tobytuttle's Avatar
Re: lowering blocks
i agree ,at one time I tested with a 4'' block and it was to much for the geometry..that was with a 4'' coil and a 4'' block....too much....so i went with a 6'' spring and a 2.5" block and that worked (for the oldstyle trailing arm set up)
Old 04-08-2012, 02:28 PM   #5
WEBBY1
WEBBY1's Avatar
Re: lowering blocks
96 3500 ext cab... was thinking about a 2/4 drop... cut coil out the front and figure out something for the rear. any ideas would be great. trying to stay Away from spending tons of money..
Old 04-08-2012, 02:28 PM   #6
cdowns
cdowns's Avatar
Re: lowering blocks
like trying to run in a track meet with stilts
Old 04-08-2012, 02:31 PM   #7
tobytuttle
tobytuttle's Avatar
hanger/shackle for the rear...spring/or spindle front...
Old 04-08-2012, 02:35 PM   #8
WEBBY1
WEBBY1's Avatar
Re: lowering blocks
djm has a kit with a coil up front and a hanger/shackle for about 260.plus shipping.. am i gonna HAVE to run shocks? they also offer shocks for a 120 bucks and give free shipping.
Old 04-08-2012, 02:43 PM   #9
tobytuttle
tobytuttle's Avatar
Re: lowering blocks
maybe for the rear, i would say with a 2'' in the front...no ..then again find the collapse spec. and go to your local parts store and buy them there....but all the way around you could get away running your stock shock set-up....IMO
Old 04-08-2012, 02:53 PM   #10
WEBBY1
WEBBY1's Avatar
Re: lowering blocks
thanks
Old 04-09-2012, 12:52 AM   #11
SCOTI
SCOTI's Avatar
Re: lowering blocks
Lowering blocks would not work in your application as the rear sits below the spring pack. The rear end would have to be flipped above the spring pack 1st to use blocks for further drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-09-2012, 04:05 PM   #12
WEBBY1
WEBBY1's Avatar
Re: lowering blocks
thx
Old 04-09-2012, 04:12 PM   #13
barry h.
barry h.'s Avatar
Re: lowering blocks
I lowered mine with 3in blocks and i am having a problem with the pinon angle and putting the u-joins in a bind,which is causing a real bad bouncing feel below 30 mph.i found some lowering blocks at speedway motors that are made for 60-72 trucks.i am putting 2 in blocke which should correct the pinon angle and i hope it correct the bounce also.
barry h. is offline   Reply With Quote
