04-08-2012, 05:36 PM | #1 |
Air Ride Install.. Questions about location of components
This is going into 65 Burban. I know I will be mounting the tanks between the rear quarter and the frame however wondering where alot of you mount the rest of the gear. I would like to be able to access it for troubleshooting etc so I was thinking about putting everything inside however wouldnt that also put the pressure relief inside the cab as well making it noisy when lowering? With it laying frame if something went wrong, near impossible to get to.
Looking for ideas, suggestions. |
04-09-2012, 11:03 AM | #2 |
Happy to be here
Re: Air Ride Install.. Questions about location of components
Any Burb owners with pics?
04-10-2012, 08:47 PM | #3 |
Bueller.......
04-10-2012, 09:30 PM | #4 |
Square
the closer you run the valves to the bags the less air it will take to fill them. thats about as helpful as I can be on a burb.
Squarebody Syndicate |
04-11-2012, 04:06 PM | #5 |
needs more $$$
Have you already purchased your valves? The only reason I ask is because if you haven't, I would recommend you getting some type of manifold set up like accuair's for sheer simplicity of installation and room it takes up. I think it's well worth the additional $ when comparing it to 8 separate valves.
1970 2wd Blazer |
04-11-2012, 04:39 PM | #6 |
Heres how my buddy did his 63 burb.
2 compressors mounted on a swing down bracket at rear pass side. tank in center valves etc for rear in homemade vented box(which will be painted black) on drivrs side rear.
Tim Road Hounds |
04-11-2012, 05:57 PM | #7 |
If you had to run the valves inside, you could laways route the dump outside in order to keep the noise down. As for compressors, I mounted mine on the back part of the frame right behind the rear bumper. I am not sure if there is room for this on a 65 burb, but might be worth checking out.
