04-08-2012, 08:01 PM | #1 |
What are the Best Fitting Headers for a 67-72 Chev!
What has everyone been using for headers for a 350. Seem to have some clearance problems with my Hooker headers. Pics would be helpfull if you can also provide them and part numbers you guys are using.
04-08-2012, 08:36 PM | #2 |
Re: What are the Best Fitting Headers for a 67-72 Chev!
I just installed a set of Summit full length headers (Part #SUM-G9006) on the 327 on my 68. Closest thing to a clearance issue I'm having is the clutch linkage rubbing a little on the driver side header.
04-08-2012, 09:09 PM | #3 |
Here are my pics with the clearance problems on the bottom frame..
04-09-2012, 03:38 AM | #4 |
i have headman longtubes from summit. The cheap non ceramic ones. They fit fine. The only issue is getting number 3 plug out is kind of a ***** but doable. 72 c20/350/auto/AC/PS
04-09-2012, 07:54 AM | #5 |
I have Headman Torque Steps and they fit fine. I've also had Headman Elites which fit fine. I've never had any headers that didn't fit. I have only had issues with clutch linkage clearance with some headers. On my automatic trucks everything just bolted on.
04-09-2012, 08:41 AM | #6 |
C/10 junkie
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
04-09-2012, 09:34 AM | #7 |
The headman elite fit great...just a little tight getting the driver side in place. I disconnected the motor mount to raise the motor a little to keep from scratching the coating on the headers.
70 chevy long bed 72 gmc short bed 69 427 corvette (next project) |
04-09-2012, 11:14 AM | #8 |
As you can see on my clearance problems on the bottom frame the headers are touching on both side, these are hooker headers. Do the Headman headers have more clearance on the bottom frame?
04-09-2012, 11:17 AM | #9 |
04-09-2012, 02:41 PM | #10 |
if it is just clearance problem on the one side// i'd loosen up everything up and lift to take weight of the engine and wiggle stuff for betterer clerance
04-09-2012, 03:13 PM | #11 |
Both sides are touching the frame. That's why am asking the question of what others are using for header brands. Thanks anyway..
04-09-2012, 03:15 PM | #12 |
04-09-2012, 04:50 PM | #13 |
Hedman Elite Thermal-coated Headers...........Period. Best D**n header for our trucks.
1 5/8 tube with a 3 in. Collector. $330.00 for the pair at Summit. Part# 69890.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
04-09-2012, 05:38 PM | #14 |
I ordered D-port Sanderson's from ECE and they fit perfect! ECE has the best price I could find.
04-09-2012, 05:48 PM | #15 |
I have the headman elite thermal coated...part #69890...just as 96blazr stated...perfect fit once you get them in place.
04-09-2012, 05:53 PM | #16 |
What?
I don't know if Hooker is making headers anymore for our trucks, but I ran a set of Hooker Super Comps in my burb and they fit beautifully. Lots of clearance in the places that were tight, and they went in and out very easy with out having to remove anything but the clutch Z bar (and obviously the spark plugs).
Chris 1968 K20 Suburban 1972 K10 LWB PU |
04-10-2012, 10:09 AM | #17 |
I read that Hedman just came out with a new mid length header for 67-87 trucks. 1 5/8" part # 69016/69010 or 1 3/4" part # 69026/69020. I think I will be trying a set on my 67.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
04-10-2012, 10:39 AM | #18 |
I used Doug Thorley and they fit perfect and have never had a leak after about 10,000 mi
Posted via Mobile Device Posted via Mobile Device |
04-11-2012, 12:10 AM | #19 | |
C10 addict
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
04-11-2012, 11:54 AM | #20 |
+1 on doug thorleys....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-11-2012, 11:51 PM | #21 |
I broke my motor in with a set of hedman headers they fit fine with no frame rubbing or anything. Waiting on my doug thorley headers hopefully they will be here next week it has been a long wait for em.
1969 C10 LWB GMC. 1970 K5 Blazer 1971 K10 Burb Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=529970 Shawn |
04-12-2012, 12:30 AM | #22 |
I forget what header i'm running, but I have a problem taking #6 plug out. does any one else?
04-12-2012, 12:36 AM | #23 |
C/10 junkie
Anyone notice any differences when running the engine in the six cylinder position or the rear holes?
04-12-2012, 06:26 PM | #24 |
+Thanks for all the replys guys! What do you think between long tube or short tube headers???
04-12-2012, 07:32 PM | #25 |
Sandersons on my yellow 69 fit great.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
