Old 04-08-2012, 09:58 PM   #1
gramps77
I HATE brake lines
what do you guys use to get the brake lines loose? Im trying to replace the 3 rubber portions and Ive never had so much work. I'll now need to replace both tube from the proportioner to the rubber hose to the front brakes. Looks like I'll be needing the rear as well. I even used the correct 6 point tube wrenches. Out come the vise grips and that was the only way to get anything loose but the tubing is now screwed. I was replacing only cause one of my buddies had a rear swell so much it wouldnt pass fluid to bleed the rear brakes. Good thing I did, I cut the driver front and it was swelled internally. Pass side was good
I was doing all of this in the first place because I was replacing the master so figured I would now so I didnt need to bleed again later. sorry for the rambling.
back to the original question, How do you guys break em loose?
gramps77 is offline   Reply With Quote
Old 04-08-2012, 10:28 PM   #2
bilfman
bilfman's Avatar
Re: I HATE brake lines
I always try line wrenches first, if they do not let go with a good push I break out the vice grips right away before there is any damage to the nut. I will only ever use "Vice-Grip" brand grips. Then get a good fit over the fitting, basically max vice action without damaging the nut. From here I will tap with a hammer to create and impact action to break it loose. I have also put a closed end wrench over the end of the vice grip to extend the grips the gives you a long very torquey push, just push slow and steady. I have never lost a battle doing the above and I have worked on many old vehicles
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-09-2012, 09:43 AM   #3
donut
donut's Avatar
Wire brush the fittings to knock off most of the rust and scale, hit them with PB and let 'em soak. I used to hit them a day before I tried to remove them.
I've also put the wrench on and "shock it" with a hammer, another wrench, rock something to knock it a little. Sometimes the blow is enough to break the rust seal.
Still failing? Cut the steel line and use a box wrench, of course you'll have to replace the steel lines.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 04-09-2012, 10:51 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
soak them,and turn a touch tighter sometimes
line wrenches,or claw socket(comes from side)
vise grips last resort.... cause
if they are that bad, they prob need the fix anyway
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-09-2012, 12:44 PM   #5
hrc200x
I'm sure I will get lots of flack for this, but here in MN when a truck has seen road salt for 20+ years I use torches, use torches on brake bleeders also. Get them almost red hot, clamp a vice grip on and they will break loose, and it usually doesn't ruin a thing (nut still spins on the line). Maybe in California where no road salt you could get away with less heat, from a propane torch. Gotta be careful when next to a rubber line or close to the wheel cylinder where rubber seals are. In my opinion heat is the only chance of saving a line on a vehicle from Minnesota, I've done it in the past and will into the future. Just gotta be smart about it, maybe want truck outside and away from buildings, not in a grassy field, water/fire extinguisher close by.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 04-09-2012, 12:51 PM   #6
67swb72klb
67swb72klb's Avatar
x 2 mi trucks same rust thing mapp gas works good
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 04-09-2012, 02:36 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
And when you re-assemble your new replacement parts,... put a little anti-seize on the threads, so it won't happen again.
Keith
Convert to disc brakes.
Old 04-09-2012, 02:49 PM   #8
East End K5
just cut them out and replace all new....it sucks but in this area of the truck i just dont waist the time. New lines are soft and easy to bend making it worth the while...
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP
[B]1972 Chevrolet K5 Blazer RIP
1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP
1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP
[B] 1995 Chevrolet Tahoe 2D [B]
East End K5 is offline   Reply With Quote
Old 04-09-2012, 05:33 PM   #9
maskale
Bought them, haven had to use them yet, but reviews are good.
Amazon.com: Vise-Grip 7LW Locking Wrench With... Amazon.com: Vise-Grip 7LW Locking Wrench With...
maskale is offline   Reply With Quote
Old 05-11-2013, 03:16 PM   #10
chevy72blu
chevy72blu's Avatar
Bumping a year old thread with the same issue. Soaked in PB blaster for a good 2 hours and the rear hose nut at the dist block simply does not want to budge. The others all came off pretty easy, but this bugger wants to round itself off. I really dont want to replace the lines.
Using a line wrench before anyone asks....
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-11-2013, 07:30 PM   #11
donut
donut's Avatar
I just recently did one of my front rubber lines. Had to add heat with a propane torch to budge the line out of the end of the rubber line. I was replacing the rubber, but saved the steel line and fitting.
Old 05-11-2013, 08:20 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Dad always said go tight first then loosen the up. Just enough tight to break the threads loose
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 05-11-2013, 11:28 PM   #13
wraprail
wraprail's Avatar
We don't have rust here in the desert!
wraprail is offline   Reply With Quote
Old 05-12-2013, 10:35 AM   #14
hatzie
Moderator
hatzie's Avatar
Brake lines are dirty nasty jobs that require some patience.
If the ferrule is rusty then the hard-line inside is prolly rusty. I usually assume I'll be replacing a stuck hard-line. I cut off the line, spray PB Blaster on, then strike the fitting firmly and squarely on the top with a hammer. With the line cut off I can use a 6point 1/4" drive socket to unscrew the ferrule.
I just replace crusty wheel cylinders... They're usually less than $15 brandy spankin new. No leaks and no rust.
Rubber lines get the cutoff wheel treatment right away... Assuming I can't get the hard-lines out of em.
Master cylinders and combination valves usually respond to cutoff lines, PB, hammer, and a 6point socket.
Caliper bleeders come out with my hot blue wrench and Vise Grips after I completely strip em down to the bare casting. If they're broken off flush I MIG a #10 nut to the end of the bleeder and heat the whole casting with my blue wrench till it glows bright incandescent red.
Heating with a 1/2" diameter brush flame (Hi-Temp) propane torch can get smaller iron castings to a very dull red and melting paraffin into the stuck threads will sometimes loosen the stuck stuff.
Wipe some Never-seeze on the threads and the portion of the hard-line inside the ferrule so it'll come back off next time. I Never-seeze bleeders on everything I own as soon as it gets home. The $2 rubber bleeder caps keep the salt and crud out of the inside of the bleeders so they are a must-have item. Any new trucks, cars, and bikes get em right away along with w quick shot of Never-seeze.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
