![]() Join Date: Sep 2004
Disc brake swap tie rod questions
Ok so in order to swap on disc brake spindles, all the needs to be changed is upper and lower ball joints and tie rod ends. But from what I can tell both inner and outer tie rods and different sizes 68 vs 72.
So if I buy 72 outer tie rods they wont work with the adjuster sleeves on the 68. So if I buy new inner and outer tie rods, and adjuster sleeves, will the 72 inners work with 68 center link? Im guessing this will work? Lists pitman and idler arms the same part number for 68 vs 72.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
| Bookmarks |
