Old 04-09-2012, 01:32 AM   #1
chevy truck crazy
chevy truck crazy's Avatar
Problems running on ethanol, plus a few fun picts in Boise.
After living in Boise 3 years I finally got my truck out of storage and brought it up here from Utah. My original plan was to drive her the whole way 260 miles but half way she broke down and had to get a ride from a flatbed..The problem was a mixture of things dealing with spark and bad fuel and I figure water and crap in the tank. Has anyone had problems running on ethanol fuel in these old motors, everyone I talk too says its bad, I found a few places that still sell fuel with out ethanol but I was wondering if maybe I should try adjusting the timing and a few things to make it run on the ethanol fuel, I def see a difference on the performance and will try to always just by the good fuel while its still available. Well a few picts of the old trucks debut appearance in Downtown Boise ID..
chevy truck crazy is offline   Reply With Quote
Old 04-09-2012, 01:43 AM   #2
R.L.
R.L.'s Avatar
Re: Problems running on ethanol, plus a few fun picts in Boise.
Nice looking truck. I don't think ethanol is very good on fuel lines and I can't keep a lawn mower or a weed eater but a few years and I think it's the ethanol I WAS using in it. I've found a place near where I live that sells pure gas and thats what I'm going to run in my lawn equipment and my carbonated vehicles when passable.
R.L. is offline   Reply With Quote
Old 04-09-2012, 03:43 AM   #3
sanford66
sanford66's Avatar
Nice looking truck and great pics! X2 on the post above. The new ethanol fuels don't work well with the old engines in our trucks. Luckily we don't have that fuel mix around here yet. There are lots of good articals on the net to read up about on it. It's not a good thing. Put some good fuel in her and i think she will be fine. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 04-09-2012, 07:49 AM   #4
I have no problems running ethanol in anything new or old,they all require the same thing to run. The problem with ethanol is "not running". It breaks down and turns into a useless toxic and less flammable liquid that needs to be disposed of...real great for the environment,right? It's the same as having water in your tank...what,15% is it? It's ok when fresh but it has virtually no shelf life,at least compared to good old real gasoline. It causes fuel system problems in anything it's in after a few months. If your truck started and ran a while it should only require draining the BS out and replacing with good fresh fuel. I'd run some Sea Foam through it.
Old 04-09-2012, 09:29 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Pepsi Cola? Couldn't resist...
SK hit it right on the head... when ethanol sits... it does mean and nasty things to rubber fuel lines and stuff.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-09-2012, 09:45 AM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Gary
Red and white is Coca-cola not pepsi!!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-09-2012, 10:10 AM   #7
carnell71075
What wheels are you running on your truck. They look nice, would like to get a set for my truck.
carnell71075 is offline   Reply With Quote
Old 04-10-2012, 12:20 AM   #8
chevy truck crazy
Thanks everyone for the compliments and response to ethanol..I got my truck running again like previously stated and definetly learned the lesson the hard way on letting these old girls sit, I drained the tank and changed all the fuel filters plus new plugs and wires and she runs great as long as I put 91 octane with no ethanol at 440 a gallon, ouch... Also one of ya asked what wheel im runnin they 295/50/15 tires on 15/10 rims. the brand of the wheel is ION, I pretty sure you can still find them on wheels site and even jegs has them If I remember right.
Old 04-10-2012, 12:43 AM   #9
longbed67
longbed67's Avatar
Along with what special-k said, it also eats out your seals, gaskets and any material that is rubber or plastic.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-10-2012, 12:52 AM   #10
oldschool18
oldschool18's Avatar
thats a nice truck like the two tone.....and there was a good read in hotrod mag a few months ago if i remember i will see what month it was, but the ethanol isnt bad but it is like special-k said it breaks down but the article was about running straight ethanol in carb engines and you do have to change over the fitting on the fuel lines and on the carb but the ethanol is better than straight pump gas for many reasons even gas thats not mixed with ethanol, ethanol is cheaper but it does burn more so it works out the same but the ethanol after it is burned cools quick unlike regular gas.......if you get a chance look it up it was a really good read and something to think about cause who knows what gas where going to be able to buy 5 years from now
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
