Old 04-09-2012, 10:03 AM   #1
dmartin1
dmartin1's Avatar
4 speed to a th400 auto..please help
I've searched the faqs and forums but never found anything clewr especially for the 73-87's ..does anyone got a list of what I will need all together? I just need some help I would love to swap out the old granny low 4 speed for a th400 while ky engines out.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 04-09-2012, 04:30 PM   #2
xrcr
Re: 4 speed to a th400 auto..please help
I'm doing a 350swap. I got a brake pedal, column shift column, and had to switch the tailshaft so I could go to a single driveshaft. You can also cut your front diveshaft but you will need a slip in yoke. Then tranny lines and a cooler or radiator for auto transmission. I might have missed something but I know I'm close.
xrcr is offline   Reply With Quote
Old 04-09-2012, 04:48 PM   #3
slinginrods
slinginrods's Avatar
I want your clutch setup( pedals bell housing etc.)
slinginrods is offline   Reply With Quote
Old 04-09-2012, 05:42 PM   #4
jame
Remember the electric kick down switch, wiring and cooler lines if you find a parts truck. If you remove the clutch pedal can you see what it stops against. I have a manual and my pedal is coming up way too far.
1963 chevy shortstep 327
1965 c60 292
2007 Ram 3500 5.9 cummins
jame is offline   Reply With Quote
