Old 04-09-2012, 02:33 PM   #1
doubledoyle
New guy with some questions
Hi guys and girls
My names Dale and from the UK, im the happy owner of a 51 merc coupe and a 63 longbed fleetside.
Ive only recently bought the C10, infact im pretty sure the previous owner was on here before.
Anyways heres a picture of my c10, ive got a couple of questions in regards to sectioned front cross members but ill put them up soon.
doubledoyle is offline   Reply With Quote
Old 04-09-2012, 02:37 PM   #2
hopped up
hopped up's Avatar
Re: New guy with some questions
nice truck! lets see that merc too
hopped up is offline   Reply With Quote
Old 04-09-2012, 02:37 PM   #3
1963c-10
1963c-10's Avatar
Welcome from across the ocean. Great looking 63 you have there. When you get your questions, ask away. More pics are always great too. Looks like its been converted to 5 lugs, so somebody's already done a little work on it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-09-2012, 02:38 PM   #4
oldsnakebite
oldsnakebite's Avatar
Welcome Dale, I too am a neebie to this site. Ask away! On my 64 c10 I swapped the entire cross member with a 1984 model c10 and it bolted right up. Now it's 5 lug disk brakes. Marty
I have not failed. I’ve just found 10,000 ways that won’t work.
oldsnakebite is offline   Reply With Quote
Old 04-09-2012, 02:44 PM   #5
A.T. RockDriller
A.T. RockDriller's Avatar
We sure like yer truck...
Is that a right hand driver...?
Welcome, Dale.
We're lookin forward to hearin your questions.
There are some pretty top-notch folks on here....
And, of course,....we sure need some more pic's of your truck.(interior and engine bay , too), cause we're pretty nosey around here.
....and some of your Merc..too ....
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-09-2012, 02:46 PM   #6
doubledoyle
Hi guys
ill stick a couple of pic's up of my 51 then ask some questions next thanks for the warm welcome
started out something like this
then decided to sort the chop out and change the rear screen along with some bags
Old 04-09-2012, 02:54 PM   #7
doubledoyle
Ok then guys
I need a little advice, ive recently bought the C10 as a easy to finish project, im planning on sticking a 2.5 turbo diesel engine in it because the cost of fuel over here has gone through the roof,
Anyway first thing i have noticed is there is no rear cross member, Has anyone on here made one? i only need it to pickup the new shocks ( ive got a shock relocating kit )
Right next i think the gearbox cross member is missing? heres a picture
And heres the biggest problem, the seller had the front cross member sectioned around 1.5" but ive now noticed that the front tie rods have not got enough clearance, the previous owner has bolt the front cross member in its orginal position which means there is a 1.5" gap between the top of the cross member and the chassis, he only has it on the bolts that pass through the side of the chassis not the bottom.
The problem is i need the truck on the road quick so im thinking of packing the cross member out so its no different than stock, or is there anyway of sorting the tie rod question with ease
Old 04-10-2012, 01:20 AM   #8
Captainfab
60-66 Nut
Welcome to the forum Dale
As for the missing 'gearbox' crossmember, the original typically supports the bellhousing. It looks as though this one has been removed to accomodate an automatic trans. Since you are installing a totally different engine, you will likely have to fabricate a trans crossmember to work with the engine and trans you go with.
The original rear shock crossmember is a bit forward of the differential, with a couple brackets for a thru bolt to attach the top of the shocks.
As for the front crossmember, fabricating a filler piece between the crossmember and the frame would be the quickest and easiest to get you on the road.
I'm interested to see the 2.5 turbo diesel engine and trans installation.
Old 04-10-2012, 10:22 PM   #9
70cst
70cst's Avatar
Hey doubledoyle ....
from Ohio and to the forum. No doubt you have some cool lookin rides
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-10-2012, 10:48 PM   #10
CRGRS 66
CRGRS 66's Avatar
Welcome Sir, like the C10, she is long and low, but not too low!
CRGRS 66 is offline   Reply With Quote
Old 04-11-2012, 01:53 AM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
