Old 04-09-2012, 03:37 PM   #1
Satin69
Factory Air Pres gauge for bags?
I have recently bought a set(4) of Dominator 2600 bags for my '69 SWB. I really want to use a cluster that includes a factory gauge from one of the big trucks to maintain a stock appearance. Has anyone done this with success? I have 2 3 gal tanks with Viair 400 compressors.
Satin69 is offline   Reply With Quote
Old 04-09-2012, 05:09 PM   #2
theastronaut
theastronaut's Avatar
Re: Factory Air Pres gauge for bags?
I'm planning on doing the same thing with my '66. A 60-66 gauge goes up to 150psi, not sure what the later model gauges register though. I did some searching and found that 150 psi max tank pressure would be adequate.
theastronaut is offline   Reply With Quote
Old 04-09-2012, 05:32 PM   #3
Satin69
My gauge is to 150# as well. I know it will work with 1 tank but will need to somehow get another to measure the other tank? Or is there anyway I could tie the two tanks into one gauge?
Old 04-11-2012, 12:50 AM   #4
edflores
If they are teed together, they will be at the same pressure
edflores is offline   Reply With Quote
Old 04-11-2012, 12:36 PM   #5
Satin69
Would there be anything wrong with that?
Old 04-11-2012, 12:43 PM   #6
theastronaut
I think it's typical to tie the tanks together for more available air volume. I can't think of any good reason to leave them separate.
Old 04-11-2012, 12:45 PM   #7
Satin69
Thank you for the input. I couldn't think of reason not to but I am still new to air.
Old 04-11-2012, 01:03 PM   #8
theastronaut
I'm new to it too, only have my bags installed so far but no plumbing, valves, tanks or compressor yet.
Old 04-11-2012, 01:08 PM   #9
Satin69
Just got the rest of my kit in today. I hope to have them on tonight!
Old 04-11-2012, 04:01 PM   #10
tubbedII
needs more $$$
tubbedII's Avatar
If the gauge only goes to 150, I'd plumb in some type of pressure valve so you don't send more than 150#'s to the gauge and potentially break it. If that fails, then you'd have a leak in your tank and your comps would not turn off.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 04-11-2012, 04:03 PM   #11
Satin69
Great suggestion Tubbed. I would probably cry if my brand new gauge blew up.
1956 GMC undergoing LS Swap
