Old 04-09-2012, 04:35 PM   #1
bbobb
Stupid me ..Silly question
I have 3 inch drop spindles only in the front and 5 inch drop coils only on the rear of my 69 c10. What is the numbers such as 4-6 drop that apply to this set up. And what should i expect from the quality of my ride and handling
bbobb is offline   Reply With Quote
Old 04-10-2012, 01:14 PM   #2
69gmcc10
69gmcc10's Avatar
Re: Stupid me ..Silly question
I am not quite sure what information you are asking for, but the 3 inch drop spindles in the front will have little to any ride quality difference compared to stock. The rear springs are going to be stiff and I would recommend 2 inch blocks and 3 inch springs, just to keep a better ride quality.
69gmcc10 is offline   Reply With Quote
Old 04-10-2012, 01:16 PM   #3
ctandc
Maybe this will help a bit
http://www.earlyclassic.com/tech.asp...nce%20Photos-2
____________________________
ctandc is offline   Reply With Quote
Old 04-10-2012, 01:49 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
If you are currently sitting at 3" drop in the front (spindle only) and need to get to 4" of drop... best solution is a 1" drop coil.
In the rear you are currently at 5" drop (via coil spring) and need to get to 6" of drop..... best solution would be a 1" lowering block.
The ride quality shouldn't change much if any. Only things to worry about are axle to frame clearance out back (don't want to bottom out). And hopefully your front springs aren't worn out to the point that you don't see any height change when installing the new 1" drop springs.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-10-2012, 01:57 PM   #5
bbobb
I think i am where i need to be with the 3 inch spindels at front and 5 coil drop at rear. Does this mean i have a 3/5 drop. This is the part i do not under stand
Old 04-10-2012, 02:59 PM   #6
69gmcc10
69gmcc10's Avatar
yes, that is exactly what you have
Old 04-10-2012, 03:33 PM   #7
bbobb
Thanks for the replies folks. Loving the forum more and more every day
Old 04-10-2012, 04:47 PM   #8
jimmydean
jimmydean's Avatar
Yes a '3/5' drop usually means 3 front, 5 rear. Usually given as 'front/rear'. You got it.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
