Old 04-09-2012, 06:14 PM   #1
SB'72
SB'72's Avatar
12 bolt rearend
Looking at upgrading my 12 bolt rearend (1972 C/10). Looking at getting the Trutrac with 3.42 gears, also thinking about upgrading to rear disc brakes as well. Currently have 3.08 gears with drum brakes. Any ideas on the brakes, and thoughts/feedback on the gears and Trutrac.
SB'72 is offline   Reply With Quote
Old 04-09-2012, 08:15 PM   #2
Ole Greenie
Ole Greenie's Avatar
Re: 12 bolt rearend
I too am looking to swap 3.08 gears for a 3.42 set with LS (Limited Slip) so this thread interests me. I chose the 3.42 due primarily to having an OD tranny. The 3.42 set seems to be a good gear as GM still uses it in their new trucks (10 bolt) today. Kind of torn between the Auburn LS and Detroit LS though. subscribed...
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 04-09-2012, 08:53 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: 12 bolt rearend
Just put in 3.42 in my 12 bolt, also did the camaro calipers, works well so far.
http://67-72chevytrucks.com/vboard/s...d.php?t=518599
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-09-2012, 08:56 PM   #4
406 Q-ship
406 Q-ship's Avatar
Re: 12 bolt rearend
Here is the Summit link to the Truetrac
http://www.summitracing.com/search/B...c&autoview=SKU
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 04-09-2012, 09:32 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 12 bolt rearend
I have a Truetrac, 3.73's, Moser axles and Moser diff cover/brace in my 12 bolt also. Camaro calipers/Impala SS drilled & slotted rotors. I haven't driven it yet with the Truetrac, but when I was doing my shopping, everything I heard and read about the Truetrac was in line with what I needed. Try doing some searching on Team Chevelle (www.chevelles.com), a lot of those guys run the Truetrac in their car 12 bolts.
I will say that I have run the Auburn HP Series LSD in another truck I had and it performed well also.
And what good would a post be without pics???
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-09-2012, 09:36 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: 12 bolt rearend
Adam, what is the purpose of the diff cover brace, besides it looking real cool ?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-09-2012, 09:41 PM   #7
Already Gone
Re: 12 bolt rearend
I've read and researched tons of stuff on diffs and I agree, a 4L60E or 700R4 with a 3:42 gear with Tru-Trac is a great combo for all around use.
Old 04-09-2012, 10:01 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 12 bolt rearend
The two allen head studs on each side of the 'Moser' logo in the pic above go all the way into the gear case and adjust up against the bearing caps on each side of the differential. They are supposed to stabilize the caps and keep them from 'walking' or moving around under load.
Adam
Old 04-09-2012, 10:10 PM   #9
RexDodge
Re: 12 bolt rearend
There is a member on here that makes the brackets to bolt the Camaro and Cadillac calipers onto the 12 bolt. That's on my list for next winter.
RexDodge is offline   Reply With Quote
Old 04-09-2012, 11:47 PM   #10
AusTx68
AusTx68's Avatar
Re: 12 bolt rearend
Right, here is the link: http://67-72chevytrucks.com/vboard/s...d.php?t=382633
I used Captain's brackets for my rear brakes. Came out nice and they work great. I'm using an Eaton posi with 4:11s and a 700r4. I wouldn't change a thing.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 04-10-2012, 07:02 AM   #11
dznucks
dznucks's Avatar
Re: 12 bolt rearend
I am currently working on a similar project.
12 bolt with Eaton TruTrac and 4.10's. Using Cadillac D-52 calipers, Astro Van Rotors, and Captain Fabs brackets.
I got the gears shimmed correctly, just need to clean it for final assembly and install it.
dznucks is offline   Reply With Quote
Old 04-10-2012, 08:45 AM   #12
dennislbrooks
dennislbrooks's Avatar
Re: 12 bolt rearend
I have been running 82 camaro calipers on the rear for a few years. They perform well but they do turn the emergency brake into a parking brake. To get mine to hold at a safety check beforee I shift into drive, I need to depress the pedal then pull the lever handle as much as I can get. I can just pass the test.
The foot parking brake may apply a little more pull. How did others fare on this?
It is kind of a toss to me on disc on rear. My 2006 WT 4wd has drums. My former 2002 Z71 4wd had disc.
dennislbrooks is offline   Reply With Quote
Old 04-10-2012, 09:48 AM   #13
RexDodge
Re: 12 bolt rearend
Not to pirate the thread but what year on those Astro van rotors?
Old 04-10-2012, 01:03 PM   #14
dznucks
dznucks's Avatar
Re: 12 bolt rearend
1992-2002 AWD Astro Van. This is one of the setups Captain Fab offers brackets for. There is a lengthy thread in the Vendor section.
For anyone looking for these rotors, Summit currently has a set of Astro van drilled and slotted rotors on clearance for $50 each. I almost bought them, but then i would have to change the fronts to drilled and slotted too.
Old 04-10-2012, 01:34 PM   #15
SB'72
SB'72's Avatar
Re: 12 bolt rearend
Thanks for the ideas and feedback. Anyone know of a complete disc brake kit that works on the truck 12 bolt. By the way I have a TH350, and thought that 3.73 in the rear would be to low for me. What do you think about the change from 3.08 to 3.42, will it be a noticeable jump?
Old 04-10-2012, 02:07 PM   #16
Jay W
Jay W's Avatar
Re: 12 bolt rearend
This is a copy of an email from the guy i bought my posi from.
"Jason-
We ship to Canada daily. Here is what we can do for you:
$450 - GM 12-Bolt Truck Eaton Posi Unit - 30 Spline
$135 - GM 12-Bolt Truck Ring & Pinion (3.73 Ratio)
$65 - GM 12-Bolt Truck Master Bearing/Installation Kit
$100 - SHIPPING via UPS Worldwide Standard (3-5 Days)
$750 - TOTAL
You would have a flat $10 brokerage fee and the taxes would run $20-$30.
Let me know if you have any other questions.
Thanks,
BRYDON
641-751-8060
staticz2229@gmail.com"
I think shipping to the US was free. Great product for a great price. I found his stuff on ebay.
69 c10 lwb
Jay W is offline   Reply With Quote
Old 04-11-2012, 02:36 AM   #17
oldspowered67C10
Re: 12 bolt rearend
Tru-trac is a nice traction device for the street but if Im not mistaken its only offered in 12-bolt truck in the 3.73-up carrier. If you want 3.42 gears you gonna have to use a clutch or cone type. Too bad, I wanted a tru-trac but 3.73s are too tall for my th400 and 28" tires
oldspowered67C10 is offline   Reply With Quote
Old 04-11-2012, 05:54 PM   #18
SB'72
SB'72's Avatar
Re: 12 bolt rearend
Well that sucks, I came across Moser's website, and they offer the 3.42 gear set/trutrac for their 12 bolt. Since theirs is a custom rearend explains why they are probably able to offer it.
Old 04-11-2012, 09:23 PM   #19
jtp67-72
jtp67-72's Avatar
Re: 12 bolt rearend
Just had Moser build this one....true trac....3.73.....33 spline.....Grand sport brakes...kore 3 brackets....
Here's link to board member's kit for truck c5 kit.....I bought one ...but then changed to big ford bearing rear...sold mine...nice kit.....
http://67-72chevytrucks.com/vboard/s...d.php?t=415021
here's pic of kit also...........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 04-11-2012, 09:45 PM   #20
71meangreenc10
Re: 12 bolt rearend
I went from 3.08 to 3.42 along with 350 to 700R4 and the truck is alot more responsive.
The camaro calipers work well on the 12 bolts.
Smitty
71 C30 Wrecker
Old 04-11-2012, 10:57 PM   #21
SB'72
SB'72's Avatar
Re: 12 bolt rearend
Jp that looks awesome, thanks for the info.
