Where do these go? (Can't find the tread!)
I posted a while ago about these parts. I can't find the tread on where these parts go. I have looked and still no luck. i am putting my front end together and want to install them. i know that there was a diagram in the tread. Can you post it again? Thanks!
![]() Join Date: Oct 2009
Re: Where do these go? (Can't find the tread!)
they look like bumper brackets to me. But don't quote me on that.
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
The top two look like the part on top of the back of the fender, under the cowl extension.
The bottom two....? Last edited by chevy_man5; 04-09-2012 at 07:00 PM. Reason: Added Picture |
#4 | |
The two on the bottom with holes for 3/8 bolts go from the bottom of the core support, at the bottom front of yer radiator to the bottom of your grill ring. The other two go at the rear inside of your fender on top (like chevy_man5 said) and pretty much lays next to your vent tinwork....to kinda keep leaves and small farm animals from blowin in yer truck.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
I Got it BAD!
The top two are filler panels for the top of the fender under the cowl panels (fender extensions)
The bottow two are grill support brackets.
Build Thread: http://www.chevyguys.com |
Thanks but for some reason I can't picture it my head. I tried to line it up but I don't see anything it lines up with.
GMC's n H.D.'s too!
I'll go snap a picture for you. Be back in a few.
Thanks!
GMC's n H.D.'s too!
Here is the other piece.
Thanks for the pics. I see where the fender one goes. The other brackets go from the core support to the bottom of the grill or grill support? That is the problem I am having. I can't believe I am having this problem!
Ok, I see it now!!! Thanks again!
GMC's n H.D.'s too!
No problem!
#13 |
Way to pull out the camera and get it DONE....
see ya
