water pump
anyone using an aftermarket water pump? the stock truck pump outlet interferes with my cold air kit and most likely will be a prob with a ls6 intake later on....been loking at this one..the edelbrock's too much....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: water pump
I used a car intake with a truck pump. I just heated the pump housing with a torch and twisted the neck where i wanted,its just a press fit.
Re: water pump
I'm looking at using a car pump on a LQ4...anyone else done this??
A guy with a truck
Re: water pump
You will need water pump spacers to make up the difference in offset of the accessory drive. There's a few that have done it over on ls1tech...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
A guy with a truck
Re: water pump
Can also swap the pulley, but it's supposedly a huge pain...
Re: water pump
I think that's the idea of the extra wide pulley on this one?...
![]() Join Date: Jan 2012
Re: water pump
Moose, I used a water pump from a 2002 camaro LS1 and used water pump spacers from a company called Dirty Dingo. I also used there idler relocation kit. Everything cleared great then. Only issue was getting the correct length belt.
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
Re: water pump
cool, thanks man...
