Old 04-09-2012, 08:45 PM   #1
JHT67
JHT67's Avatar
What wheels fit
Will any modern Chevy 8 lug wheel fit on my 67'?
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline   Reply With Quote
Old 04-09-2012, 09:41 PM   #2
Pro Performance
Pro Performance's Avatar
Re: What wheels fit
Chevy 8-lug pattern has been the same for many years. 8x6.5..... so they should fit Ok, without problems, considering you have stock suspension or nothing crazy going on.
Pro Performance is offline   Reply With Quote
Old 04-09-2012, 09:44 PM   #3
mr48chev
mr48chev's Avatar
Re: What wheels fit
Check with the tire store you deal with to see if there is a break in what fits what. Sometimes the bolt pattern is the same but the center hole is the wrong size to slip over certain hubs.
Old 04-09-2012, 09:48 PM   #4
71swb4x4
71swb4x4's Avatar
Re: What wheels fit
I agree with street, they do all fit.
As a matter of fact I think Dodge and Ford have the same bolt pattern, but the problem there is as mr48chev eludes to, the center hole is larger on the Ford and Dodge so you are putting more stress on the lugs.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-09-2012, 09:50 PM   #5
zellway
zellway's Avatar
Re: What wheels fit
I got mine off a 2008 Dodge. Could use a bit of spacing. They will rub the sway bar and shocks if you turn to lock.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 04-09-2012, 09:52 PM   #6
Pro Performance
Re: What wheels fit
Dodge and Ford were the same for most years, but now, the late model Fords are different... they use a metric pattern.
Most aftermarket wheels these days, are not hub centric. So allowing the lugs to center the wheels, is no problem. Of course, a hub centric wheel is better, but not a necessity at all. For example, the wheels on my 8-lug truck are not hub centric, and I tow a toy hauler without issues.
You should have a lot of options out there for wheels.
Old 04-09-2012, 09:53 PM   #7
Pro Performance
Re: What wheels fit
They look great on your truck! What's cool about the Dodge wheels, is they are 5-spoke.
Old 04-10-2012, 04:46 PM   #8
JHT67
JHT67's Avatar
Re: What wheels fit
Thanks everyone, I've been going nuts trying to find tires (used) for the 16.5 rims that are on the truck now so I figured I'd look for a set of tires and wheels in a different size but wasn't sure what would fit, seems I do have more options than I thought. I'm just trying to find something on the cheap to get me by for a while, wish me luck........
Those do look good. Is there other options for the center cap, or does only the Dodge ones fit? Also what is the size of your tire wheel combo you have there?
Old 04-10-2012, 06:51 PM   #9
zellway
zellway's Avatar
Re: What wheels fit
I will look when I get home. They are the stock wheels from a friends truck. I will be getting spacers for them soon. This is the only cap that I have seen. I was running chrome lugs and no caps but I had them so I put them on. I think I can cut out the ram and put somthing in there. For the time they don't look to bad.
Erik
Old 04-11-2012, 10:32 AM   #10
zellway
zellway's Avatar
Re: What wheels fit
I tires are 265/70 17. They were on a ram 2500 quad cab 4x4. You can find them all over the place. I got a set for my dad on Cragslist for $300. They have them in silver and polished. I like the polished ones.
I have a set of spacers on the way to help with the tight fit.
http://billetwheeladapters.com/8-lug...1-5-thick.html
Erik
Old 04-11-2012, 12:19 PM   #11
Ackattack
Ackattack's Avatar
Re: What wheels fit
My dad told me Chevy also changed their 8 lug to a metric pattern for '11
Ackattack is offline   Reply With Quote
