04-09-2012, 11:36 PM | #1 |
Anything worth saving on this 73?
Did a little trading and ended up with the 73 that I got my turbines off of. Body is shot, engine is probably locked and is an 80's 305. It's a manual trans, which would normally excite the heck out of me, but decided to keep my 79 an auto, so the wife can drive it too. Got it from a friend who said he thought it has 4.10 gears. If so, I will keep both axles. I already stole a front spring and will be pulling a few other little things. Seems a shame, but will eventually take it to scrap unless I find some who wants it. Would make a great donor for someone wanting to convert to full convertible...
I'll probably hang on to all the trans/transfer case parts. Just in case or to sell/trade... Tailgate, doors, seats and front clip are all rough, but on the ground there. Posted via Mobile Device Posted via Mobile Device |
04-10-2012, 01:50 AM | #2 |
Re: Anything worth saving on this 73?
My opinion i would keep it do the 89 conversion that's what I did. Didn't spend to much my dad and I did the body work and everything else just go to the junkyard little by little start getting the things. Also a 2wd blazer are hard to fine too. Keep it and fix it up
04-10-2012, 01:52 AM | #3 |
Also one thing if you need to top for the fully convertible I one I'll sell to you let me know
04-10-2012, 04:10 AM | #4 |
If the windsheild is not cracked, I would keep it and the gasket if it looks ok. They are easy to remove, and from what I've read, not too difficult to install. I would keep the rear shackles for the front springs...never know when they might break if yo do any 4x4'ing. Brake booster and master cylinder, if anything you have a core ready to go when you need to buy new.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
04-10-2012, 04:12 PM | #5 |
Catchy title goes here..
classified ads must be posted in the proper areas. No buying and selling is allowed on the regular message forums. Also, you must be a subscribing member to post a classified ad.
thanks |
