Old 04-10-2012, 09:43 AM   #1
jason7698
Rearend ratio and stall?
71 c10 weekend cruiser/highway NO drag strip with a 468 bbc and built th350 tarnny. Looking for some advice on what stall and if I need to change the rear gear I'm pretty sure (will know soon) the truck has 3.08 gears just wondering if I should change to a lower gear when I install the eaton posi? I am running a 30 inch rear tire also... Here are some specs...
Edelbrock Performer RPM intake, 1" spacer, HEI distributor, MSD plug wires, fully rebuilt heads with new valve springs, new seals,10 degree locks, retainers and lash caps, stainless steel valves (2.25I 1.88E), full roller rockers, JoMar stud girdles, new Comp Cams xm 278h-565 lift-234/244 dur @ .50 , forged SpeedPro pistons, ARP main studs, new rings, flowtech headers.
ALL suggestions/advice wanted!!!...Thanks
jason7698 is offline   Reply With Quote
Old 04-10-2012, 12:05 PM   #2
AusTx68
AusTx68's Avatar
Re: Rearend ratio and stall?
I'll bet it makes some damn good torque. That said you could probably get away with a moderate stall. Something like 2300 with 3:73 gears.
That's just my "somewhat educated" guess. I have a 383ci/700r4 with 520 lift 244/244 cam with 2k stall and 4:11s. It makes a good torque down low so I was able to run the lower stall.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 04-10-2012, 12:26 PM   #3
CC69Rat
CC69Rat's Avatar
I'd stall it about 2500-3000, 3:55 gears. (more for freeway) 3:73 would get more 'punch' off the line yes, but then traction comes into play, .. more stressful on Ujoints, Etc. Just my .02. If Eaton makes something between 3:73 and 3:55 (?) That might be the ticket.
Do you have stock axles in the truck?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-10-2012, 01:13 PM   #4
jason7698
Yes I have stock axles..
Old 04-10-2012, 09:20 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I'd leave the 3.08's for a street cruiser.It might not jump the lights as quick but witth the 1:1 final drive ratio,you will still be able to run 65 or so on the hiway with out twisting it's tail.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-11-2012, 12:24 AM   #6
BIGKEV
One thing you have to consider with a stall is cruising RPM. Your stall HAS to be lower than your cruise RPM by at least 400 unless your running a lockup converter/trans. More info on your engine combo would help greatly in recommending the proper stall/gear. Without knowing your heads flow numbers it's hard to judge hp/tq curves, also weight of the truck as it will normally cruise will help.
BIGKEV is offline   Reply With Quote
