MPG...hmm..more like GPM
wtb- locker, posi or spool?
hey everybody,
finally got the truck all tuned up and i am trying to figure out what type of traction aid I should buy, its a 71 12 bolt rear end, with 3.07 gears right now. I have seen spools in summit for $189.00 do they affect the handling of the truck that much? and are they really that hard on the drivetrain? otherwise I was wondering if anybody had a posi or locker for sale, can't afford the prices they want for new ones ![]() its just a one wheeled wonder right now, i need to get it to do this... ![]()
(Looking for 67-72 shortwide or shortstep bed) 71 C-10, 500ci of tire shredding Caddy torque, th400, 12 bolt w/Powertrax Lock-Right. Bald Rear Tires ![]() 85 Toyota 4x4- 22r 4-banger, 5 speed, I can actually AFFORD to drive this one. |
67-72 Addict!
I think the spools cause excessive wear on the tires. If you can, save up the extra $91 and get a posi from www.tomsdifferentials.com I got my Eaton from them and have been happy.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Hot Damn - Here I Am!!
Has anyone used the True Trac listed at Tom's Differentials? $195 isn't a bad price for a new posi. Or are the Eaton or Auburn units better?
My vehicles: '90 Silverado Sport '71 Chevelle SS Convertible '70 C-10 - My Grandfather bought it new - original un-restored |
ttt
![]() Join Date: Sep 2001
I run a detroit locker. EXPENSIVE, and I wouldn't recomend it unless you're off-roading.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
ttt
im still lookin for a posi(its the 3 series i think? 3.08 ratio)
or a locker..ive decided against the spool.
just an FYI....I am soon swapping to an Eaton posi, but I have ran a $99 mini spool for two years or more. Go thru a set of tires once a year, but some of that is from tire burnout as well....so $99 can get you traction until you can get a new Eaton or locker....
New lockers (at least a detroit) are upwards of $500...FYI.
ttt
ttt
