04-10-2012, 10:11 AM | #1 |
Partiing out 21,000 miles 1961 1/2ton
Have a ton of parts, most out of a 21,000 garage kept 1961 1/2 apache shortbed fleetside. If better pictures are wanted, please just ask. Buyer to pay for shipping from NC 28301. I have a main underdash harness, inner fenders and more parts to get pics of yet, just ran out of light last night. Please list lot# to help me out. Thanks...Jon ALSO** LOOKING TO BUY/TRADE FOR A FACTORY PASSENGER SIDE STANDARD MIRROR ARM & ROUND MIRROR W/BOTTOM MOUNT STUD. THIS IS A CAST PART, NOT LOOKING FOR REPO *** PAYPAL, CHECKS & MONEY ORDERS ACCEPTED FOR PAYMENT
Lot 1 - Fuel neck filler and gas cap $5
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 10-10-2012 at 11:26 AM. |
04-10-2012, 10:12 AM | #2 |
Re: Partiing out 21,000 miles 1961 1/2ton
Lot 2 - OEM AC Delco high beam selector floor switch $5 Will work on 60-66
04-10-2012, 11:21 AM | #3 |
Jon
Can you give me some info on the wire harness for under the dash, Pics and price!! may also be interested in the dash vents also, since my recent deal seems to be falling through
1962 Chevrolet S/B Fleet side Engine: 283 Transmission: 3 speed manual 2 do list !!!!!! Frame off-2 1/2" front , 4" rear Rebuild engine (or find a 327), 700R4 Trans, relocate gas tank, Bed wood |
04-10-2012, 12:27 PM | #4 |
This is the mirror that I'm looking to purchase or trade for. I need one for the passenger side. Note the bottom mount on the mirror. 1960-61 chevy
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 05-17-2012 at 09:27 AM. |
04-15-2012, 11:21 PM | #5 |
Do you know if that rear bumper will work on a 64-66?
Posted via Mobile Device |
04-15-2012, 11:34 PM | #6 |
Does the cab have a high trans hump? If so would you sell the piece in front of the hump that mates the hump to the firewall?
04-16-2012, 10:26 AM | #7 |
PM sent on lot #6
04-16-2012, 10:52 AM | #8 |
PM sent for Lot #24.
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ! My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342 My 2013 Camaro 1LE: https://www.youtube.com/channel/UCxa...wL5d6RnmfdJa1A 86 C10 "Build Thread”: http://67-72chevytrucks.com/vboard/s...d.php?t=668777
04-16-2012, 07:01 PM | #9 |
Just sent you a PM
04-17-2012, 12:27 PM | #10 | |
04-19-2012, 10:03 AM | #11 |
interested in lot #7, can u lmk total to 08753?
thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
04-23-2012, 10:44 AM | #12 |
The frame is up for parts if anybody needs anything off of it. Complete minus the steering box. 61 SB Fleetside, has all mounts and crossmembers, rearend, front end...let me know what you might need
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-23-2012, 01:54 PM | #13 |
Jon, I just recieved the parts everything looks great!! Its been a real pleasure doing busness with you!! Hope to do more in the near future
Thanks again John
04-23-2012, 02:44 PM | #14 |
No problem, John. Glad your parts arrived and thanks for letting me know they got there ok.
04-28-2012, 01:14 PM | #15 |
Received the pedal assemblies...
Thanks again!
05-02-2012, 02:09 PM | #16 |
Will be cutting patch panels out of the cab. The driver side rocker, toe board and cab coner are accounted for. The roof is up for grabs...and if any body else needs panels from it, please let me know. The pasenger side has taken a pretty good whack, so the rockers/cab corner are shot. Good pillers, good roof, rust free cab. Let me know what you need.
05-15-2012, 11:55 PM | #17 |
do you have any of the following for a 61:
- Heater controls or a delete plate for that opening in the dash - drivers side door bottom patch - radiator fan shroud Thanks, Scott |
05-16-2012, 08:15 AM | #18 |
Are you looking for the shroud for a V8 or I6? I have an I6 shroud, came out when I did the radiator conversion in my 63. I have a heater control panel...minus the cables came out of a 61 with economy heater.
05-16-2012, 10:48 AM | #19 | |
I have a V8 :-( I guess it matters if it's one or the other? Thanks. |
05-16-2012, 11:55 AM | #20 |
Yeah, they were different for the L6 and V8. Id take 20 for the heater panel. It has the mount and hardware with it. Let me take a picture of it so you can look at it 1st. Its in great shape. The knobs are gone, but were incorrect anyways...I might have a set to throw in. I would replace the lever with the new repops. The originals are cast and break easy...the new ones are stamped steel and much stronger.
05-16-2012, 11:58 AM | #21 | |
thanks! |
05-16-2012, 01:06 PM | #22 |
It'll be tomorrow before I can get to my parts. But check back tomorrow and Ill have it for you.
05-16-2012, 02:09 PM | #23 |
05-17-2012, 09:24 AM | #24 |
second series 1955 -66 fender mounted spare tire fender, hole for carrier has been filled.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 05-29-2012 at 09:50 AM. |
05-17-2012, 11:36 AM | #25 | |
