Old 04-10-2012, 02:02 PM   #1
funkytechmonkey
funkytechmonkey's Avatar
questions about air ride and allignments
I have all porterbuilt suspension, accuair elevel kit and some very expensive tires... Can anyone give me some pointers on how to dial this thing in to the perfect ride height and how to align it so I don't wear these tires out.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 04-10-2012, 02:10 PM   #2
BMERDOC
BMERDOC's Avatar
Re: questions about air ride and allignments
Yup! Here ya go. Align it at what you are thinkin will be "normal" ride height.
http://67-72chevytrucks.com/vboard/s...d.php?t=487363
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 04-10-2012, 05:50 PM   #3
six-T-seven
ok, say a guy just bolted his bags and drop spindles on and needs to get it to the alignment shop and doesn't have a trailer.
toe-in/-out is pretty easy to get "close enough" using the string method, but how does one set the camber "close enough" to drive the vehicle to the shop? what's a good starting point as far as number of and thickness of spacers on the a-arm bolts?
six-T-seven is offline   Reply With Quote
Old 04-10-2012, 07:29 PM   #4
BMERDOC
BMERDOC's Avatar
I found that you can remove ALL the shims on a stock AND most (as low as 3" at this point) lowered truck and still not have enough camber. In short if you wanna go to the alignment shop set toe and you'll be good. If you are concerned about caster to get to the shop add an 1/8" shim to the front bolts. That should add a little caster.
Nick Carter
