Old 04-10-2012, 04:34 PM   #1
c.brown
c.brown's Avatar
changing truck pan to a ls1 camaro pan 6.2l
im switching my stock truck pan to a ls1 camaro pan for clearence on my 6.2L just wanted to know what all can be used from the stock truck pan,are the bolts windage tray nuts all the same,i know i need windage tray oil pump pickup just want make sure before ordering thanks
1966 suburban slammed fuel injected 6.2L
My build
c.brown is offline   Reply With Quote
Old 04-10-2012, 08:27 PM   #2
TR65
TR65's Avatar
Re: changing truck pan to a ls1 camaro pan 6.2l
C.Brown,
I ordered a new pan from Chevy and it came with a new gasket and all the bolts.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 04-10-2012, 09:39 PM   #3
mooseknuckles
mooseknuckles's Avatar
I switched from a truck pan to the lh8 pan kit and it came with everything, but it was a "kit" tho........all of the bolts were the same.....if your buying a f-body pan form GM you prob will have to order everything!
mooseknuckles is offline   Reply With Quote
Old 04-11-2012, 07:29 AM   #4
68Stepbed
68Stepbed's Avatar
Yes, all the bolts and gasket are the same.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-11-2012, 07:16 PM   #5
c.brown
c.brown's Avatar
Originally Posted by TR65 View Post
C.Brown,
TR
thanks guys i have to order everything seperate through coach and motor
My build
