rusty 66
I hate to ask but I want to bag the back of my 66 truck and wanted to know what are the parts I need to bag just the back I don't need brakets I just wanted to bolt to the upper fram and the traling arm I have a bolt in c notch kit in already I don't really want it to be fast and I would like it to be silent when the air is released I was think of using hard lines my dad has some 1/4 stainless steel line I may consider using just need to get fittings
1947 chevy fleetmaster http://www.cbforum.net/forum/ 1966 chevy c10 long bed http://67-72chevytrucks.com/vboard/s...d.php?t=439219 1970 chevy impala custom http://www.layitlow.com/forums/index...pic=349867&hl= |
rusty 66
Re: air bags parts list
COMPRESSOR,TANK/PRESSURE SWITCH,VALVES BAGS and ur pro bally going to have to re route exhaust shorter shocks or relocate upper mounts there a few threads on here that deal with that!
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
if you just want to bag the back and dont worry about how fast they are then get a paddle valve switch like this:
http://www.ebay.com/itm/AIR-LIFT-Pad...a3b3a6&vxp=mtr but wont be silent youll hear it in the cab, the switch is also the valve so air will release from behind it. but this most likely be the easiest cheapest route to get functioning rear bags...also depending on how you want your setup.....one switch for two bags? or two switchs, one for each bag?also depending on what style pressure switch you run you may have to use a relay... heres for one switch tee'd for two bags paddle switch valve 1/4 air line( measure from tank to switch to bags and then some extra) 3 - 1/2 to 1/4 reducer fittings(two at the bags, and one at the tank to reduce the 1/2 ports to 1/4) tank viair compressor ( because they come with a leaderhose and check valve for tank) 1 - 1/4 tee compression fitting( tee'ing the bags together from line coming from switch) gauge 1 - 1/4 male compression fitting(for the air line at the tank going to the switch) 2 - 1/2 90 degree compression fitting(at the bags for the air lines coming from the tee) 1 - drain cock(to drain the tank,most tanks have a 1/4 port for drain cock but make sure the tank you get does or you may need another reducer fitting) pressure switch( may need a extra reducer fitting depending on what ports your tank comes with) now if you want a switch to both bags id say by this: http://www.ebay.com/itm/200-PSI-Dual...f493b1&vxp=mtr then you dont need to buy a gauge or 1/4 tee fitting listed above, but would need a extra 1/2 to 1/4 reducer fitting and 1/4 male compression fitting for second supply line to the second switch that you should run if your going two switchs.. this was doing it without the line you suggested using because you would have to figure out what fittings for that you would need,this is also done with out a gauge for the tank pressure or with a safty pop off valve, and depending on the pressure switch you use you might not have to use a relay..there is many different options and stuff you can add or ways to plumb everything so more fittings may be needed depending on what you choose to add...also theres different type of fittings push style, compression( i just like compression best) you could use what you prefer..all the fittings and air line I bought at a NAPA but i live by the warehouse with a big truck department so you may have to order it if you go to napa, and make sure if you use the brass style compression fittings that they are made for air line because the fittings they sell at home depot are not for air line tubing and leak( had a buddy buy some) I also ordered some fittings from here a couple times and seem to be fair on prices and very professional and accurate with my orders: http://airridefittings.com/store/index.php, then theres the traditional way to air bag with external vales and dumps and switchs box which is a whole different setup which would cost more and need more parts
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 04-11-2012 at 09:57 AM. |
I'll be running the same set up on the rear of my '66. The bags are Airlift D2600's. I'm planning on using manual valves. You'll also have to relocate your shocks.
![]() ![]() ![]() Posted via Mobile Device
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Oh, and you'll need taller bump stops to keep the axle from hitting the bed floor.
rusty 66
OK thanks I need to do some research and find out how I want to go I have never had air bags on any of my car
There is many ways to bag a truck, from complex to simple. Fortunately, the trucks with rear trailing arms do make it a little easier to bag the rear. Here is a complete kit with everything you need to run a manual 1/4" valve setup, with bags and brackets. No c-notch included, but you have that already.
Complete C10 Air Bag Kit |
