Upgrade water pump if installing 4-core radiator??
I was told by a friend that he thinks I have to upgrade my water pump to one that has more flow if I install a 4 core radiator. Is this true?
Re: Upgrade water pump if installing 4-core radiator??
Your friend is a Ford guy aint he... No diff in water pumps.
I have never heard of needing a water pump upgrade for a 4 core radiator, but if you do change your water pump out at some time I recommend OEM GM or AC Delco only.
At the body shop.
I put an aluminum hi flow hi pressure pump and all it did was hold the the thermostat closed. Changed back to a parts store pump and all was fixed...
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 04-11-2012 at 03:18 PM. Reason: typo |
I run stock water pumps on all my 4 core radiators (chevys and pontiacs currently) without issue.
Stock pump and radiator in the Ford, so I can't comment on that Esbstuff ![]() |
Thanks guys for the input. Yeah I never heard of having to do that.
