Old 04-11-2012, 12:26 PM   #1
thump16
thump16's Avatar
power source
okay square body guys. What wires are you using from the truck's firewall to power the ECU and LSX harness. Pics would be cool too. I know that the purple wire from original starter harness goes to ls starter but i want to make sure I am doing everything right. Thanks in advance
thump16 is offline   Reply With Quote
Old 04-11-2012, 02:31 PM   #2
ls1nova71
ls1nova71's Avatar
Re: power source
Use the big heavy gauge red wire that originally went to your HEI to power the ignition relay for your engine harness.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-11-2012, 07:12 PM   #3
clinebarger
Re: power source
Red is battery power
Pink is ignition hot
clinebarger is offline   Reply With Quote
Old 04-11-2012, 09:04 PM   #4
ls1nova71
ls1nova71's Avatar
Re: power source
That's generally true, but did they change sometime between '73 and '87? Because I pulled an HEI out of I think a '79, and got the power wire for it and it's definitley red. Ok my phone sucks and it looks pink in this pic, but it's red.
Old 04-11-2012, 10:14 PM   #5
clinebarger
Re: power source
Im putting a LQ9 in a 77 C10, The HEI lead "was" pink kinda a dirty off white now. The B+ wires were A real light red. The colors on my 85 burb are still vibrant so Pink/Red are easy to spot. I generally go by the White terminal on the end of the HEI wire.
The wire you have looks red to me, Maybe someone replaced the wire on the 79. As far as I know all 75-86 large cap HEI power wires were pink. 73/74 still used points
Old 04-20-2012, 06:01 PM   #6
mooseknuckles
mooseknuckles's Avatar
Re: power source
mine has the pink wire that used to go to the HEI, this is a switched 12v constant right?
mooseknuckles is offline   Reply With Quote
Old 04-20-2012, 07:40 PM   #7
clinebarger
Re: power source
Yes.
Old 04-20-2012, 08:14 PM   #8
Dustytrix
Re: power source
Glad yall asked that question, I will be starting in a few weeks. Ok does this pink wire go to the stud on the ecm?
Dustytrix is offline   Reply With Quote
Old 04-20-2012, 08:36 PM   #9
mooseknuckles
Re: power source
I doubt it.....mine will be connected to a brown wire from my psi harness....
Old 04-20-2012, 08:59 PM   #10
clinebarger
Re: power source
Please elaborate. There is not a stud on LS PCMs.
Old 04-21-2012, 09:02 PM   #11
Dustytrix
Re: power source
Sorry I meant fuse box, I guess I read ecm to many times.
