toe board replacement help
need to find a place that sells a front toe board. all i can find are floor boards
Posted via Mobile Device |
Re: toe board replacement help
I used whatever flat piece of metal I had lying around to replace mine. But then again I'm not going for a perfect restoration either...
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
I'm actually do that same thing right now, as far as I know there isn't anyone making them. I had to cut out the recesses for the dimmer and bend up my own. Hopefully your dimmer switch area isn't too far gone.
Can you post a picture of how much of the area you need? There are lots of guys here with parts trucks, someone may be able to cut out what you need.
