![]() Join Date: Jan 2012
5.7 or 5.3 tell me what y'all think...
Ok I'm in the middle of my frame off resto and had planned to go with a 5.3 but have had a nice offer for my complete Tahoe I was gonna remove it from. So I also have access to a low mileage 97 suburban with a Vortec 5.7 complete with tranny well I have the whole dang truck so I have just about everything I would need so what would y'all do I'm a bit torn but I know both options would make a great ill driver.
Posted via Mobile Device |
Re: 5.7 or 5.3 tell me what y'all think...
5.7
5.3 is a good engine, but you can't beat a 5.7. beside the 327 the 350 is the best all round engine chevy built, bar none
![]() Join Date: Sep 2011
I have the 5.7 in mine and really like it!
I'd go 5.3L, I was never impressed with the vortec 350 in my 97 'hoe
Cruzin
5.7 is fine with me i've never had a problem with my vortec in my daily its a 5.0 though but its stout i do every thing with it
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
![]() Join Date: Dec 2007
The architecture and of the Gen III/IV engines is far superior. However, the old SBC is much more economical to rebuild. But that savings will likely exit out the tailpipe, especially with fuel approaching $5/gallon.
5.3 all the way!! This coming from a guy who is building a truck with a 97 'hoe vortec 5.7and I like it alot don't get me wrong, I just prefer the genIII design. I got a sweet deal on a wrecked 97 tahoe so that made up my mind for me.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Can't go wrong with either motor. I had the 5.7 in my 97 Sierra sbsc and with little work that 5.7 was a mean motor and would surprise a lot of other cars and trucks that pulled up beside it.
1972 C10 SHORT BED, BLACK ON BLACK, ZZ3 CRATE MOTOR WITH B&M 250 SUPERCHARGER, HEADERS, 350TURBO TRANS, BOOST RETARD, POSI, 373 GEARS 1966 MUSTANG COUPLE, 289 HIPO MOTOR, CAM, 650 HOLLEY CARB, FULL LENGTH HEADERS, 2.5" FLOWMASTER EXHAUST, HURST SHIFTER, 373 GEARS POSI 2006 MONTE CARLO, FLOWMASTER MUFFLERS, K&N INTAKE, EXTERIOR MODS |
Exactly. As much as I like it, the 350 has had its day. It's still a good engine, but the LS series is much stronger and more capable.
1954 Ford F-100 1956 Chevy big window 1970 4x4 Blazer CST 1987 Land Cruiser 1990 Chevy K3500 454 |
Both engine are good engines when they are running properly.
Beside pure personal preference, you need to look at what each engine needs to be put in your truck, up and running, and add each route up and see which makes the most sense. Stock for stock, power is going to go in the favor of the 5.3, if you have the tune on the money. Stock '97 5.7 Vortec was 225HP @ 4600 RPM and 330 ft/lbs of torque @ 2800RPM. Stock 5.3 is up on the 5.7 in HP (most were around 290-300) and they made about the same torque numbers (albeit at over 4000RPM vs the low end grunt of the 5.7).
____________________________ |
#12 | |
bbadfred
![]() Join Date: Mar 2008
Posted via Mobile Device Last edited by bbadfred; 04-12-2012 at 04:41 PM. |
#13 |
Everybody has good points guess I just need to decide. If I sell the Tahoe then I'll have some cash to put into my build and I have a suburban that's free to me. So just gonna hafta decide ugh!
#14 |
5.3 all the way. Gen III & IV are the way to go.
Doug Looking for a 67-72 short bed driver..... |
#15 |
I'm going to be building a 5.7 as soon as I find a good core for my truck. The LS series engines are great, 5.3 is far from my favorite (mmmm... piston slap!) in the line but it's not a bad engine. 5.7's are cheap, and the most modern 350 you can get. If you're going fuel injected, the LS based is the way to go IMO, the induction on the 5.7 is what holds it back power wise in stock form. If going carbureted, the gap closes up quite a bit, especially if you couple a cam to some light porting in the vortec 350 heads.
The thing about the 5.7 is that if you already run an SBC, it bolts in, you can use your headers/mounts/accessories. I'll be putting a carb atop the one that goes in my truck though, I'm making moves for performance, not economy. If I was concerned with economy, I wouldn't run around in a 40 year old V8 pickup truck. |
#16 |
Pancho 69 c/10 step side 454/400 with 3.07 |
