Just a Member
Brand New 650 cfm Holley 0-9895 Model 4175 Carburetor
Designed as a bolt-on replacement for GM's venerable Quadrajet, Holley's Model 4175 carburetors utilize a front-mounted fuel bowl fitting, allowing you to reuse the stock fuel line. Other features include vacuum secondaries, power valve blowout protection, a spread bore flange, and a choke. The Model 4175 carburetors are available in your choice of universal calibration or direct fit replacement versions.
This is a virtually brand new 650 cfm Holley list 0-9895 Model 4175 Carburetor. It was only used to test run engine. You can tell by the pics it is new in every meaning. $326.25 Shipped. That is 25% off!!! list price $435.95 ![]()
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
Just a Member
Re: Brand New 650 cfm Holley 0-9895 Model 4175 Carburetor
more
![]() Join Date: Jan 2004
Dang, I just gave one of those away ! Nice carb.
Just a Member
gave it away as in you no longer needed it or you sold it for way less? was it also new and why did you part with yours?
It looked as new as yours & was taking up space in my garage. A board member wanted to rebuild his quadrajet but needed his truck too, so I just gave it to him. I personally don't like to sell used carbs good or not. Seems like they all need rebuilt.
Just a Member
Oh ok. Glad you helped him out. This one is literally brand new. I don't want to get rid of it...but as you said. It is sitting. I would warranty it any how
425hp409
![]() Join Date: Oct 2008
I will take it...
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
Just a Member
CHarles....you are a easy to work with and reasonable man. Let me know when you are ready
