4wd conversion
Ok guys i dont know if right spot to post in but i am looking get a 83 3/4 ton crew cab 2wd truck has 83,000 miles on body no motor or trans was a 4 speed truck with 454. I want to know how hard would it be to turn the truck to 4wd?
I searched but i couldn't find anything but am still looking. Any help will be appreciated and pics or a link to a thread will be great. Thanks |
Re: 4wd conversion
Doing just the opposite, It is much easier to go from 2wd to 4wd. The rear spring mounts and bump stop mounts are different. Also the overloads mount lower on the frame.
Re: 4wd conversion
Go to the search engine on this site and type in 2wd to 4wd conversion, you'll find some info to help you.
Re: 4wd conversion
Look at http://67-72chevytrucks.com/vboard/s...d.php?t=310493 its a older truck but will give you the idea what how much work and parts that are needed.
Re: 4wd conversion
I did this to a 85 crew cab, check out my thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=426463 Any questions just pm me!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
Re: 4wd conversion
i converted mine over, look at my truck build. http://67-72chevytrucks.com/vboard/s...d.php?t=463296
1981 Dodge D-150 (under construction) 2007 Chevy Suburban 2010 Dodge Charger R/T 1980 Kawasaki KZ 440 2004 Harley Sportster 1200 |
Re: 4wd conversion
You guys are crazy, you know they sell those things everyday!?! They made those things like doritos! Why not just buy 4X4...
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE |
