Electric fan controllers...
I'm looking for a fan controller. I have twin Spal 14" fans and was wondering how other's are controlling their fans. Recommendations please.
Re: Electric fan controllers...
I run a 165 thermostat and a 190 fan control and a overide switch ,never once had to use the overide the fans pull it down to 170 and shut them off ,they are also wired to my ac when the ac comes on so do the fans.
Posted via Mobile Device |
I am running a Centech wiring fan controller. Fully adjustable to accomodate different temp thermostats and runs off of your existing temp sending unit or off a second sending unit(how i did mine). It does not rely on those terrible looking capilary tubes stuffed into the radiator fins or through a hose fitting to the radiator. Also has a case that looks like it was finished, unlike those adjustable units from NAPA and most other auto parts stores.
This unit const about three times as much though, but i would not even think twice about buying another one whenever i need a fan controller. It has worked flawlessly so far. Here is a link to Centec wiring. http://www.centechwire.com/catalog/cooling/fc2p.shtml They had three models of controllers when i bought mine. All depending on the sending unit that is needed to control the unit. Also, before i purchased mine, i called tech support to ask a question. Who did i get on the phone? The owner of the company, and he answered every question i had without hesitation or asking an employee for help. Top notch service before i had even made a purchase. |
Old member
I only have mine on when the AC is turned on. Ran wire from fan switch to relay then to fan. The clutch fan keeps it nice and cool other wise.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
30140 Painless gives you every thing to do a nice job with many options in 4 thousand miles it has worked flawless.
![]() Posted via Mobile Device |
Parts and more parts
I considered the Centech controller, but I went with the SPAL PWM fan controller on both of my trucks. The controllers are adjustable and able to run two fans with a supplemental wiring harness. I am running dual 11" fans on the trucks.
Frank |
![]() Join Date: Oct 2005
These guys make a variety of controllers for the popular Ford 2 speed fans found in Taurus's & Mark VII's.......don't see why they wouldn't work with other fans.
http://www.dccontrol.com/selector.htm
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
I bought myself a Flex-a-lite 31165, just havent gotte around to install it.
http://www.summitracing.com/parts/FLX-31165/
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
