04-12-2012, 02:25 AM | #1 |
Active Member
Will 3/4-ton lower control arm shaft work for 1/2 ton?
I have new lower control arm shafts that fit a 3/4-ton and am wondering if they would work with my 1/2-ton. They are the exact same length overall but there are more threads on each side (and thus less shaft in the middle). Is this okay or do I need a 1/2-ton shaft. My control arms are 1/2-ton as is the truck itself
Thanks guys
-Chad '72, C10, SWB, fleet, 4L80E, 406sbc, EFI, TruTrac Blackfoot '69 C20 Suburban, PB Dropmember, 3rd row, LS3 6.2L, 4l80e, rear A/C, Dakota Digital HDX Babe: The Blue Ox |
04-16-2012, 12:18 PM | #2 |
67-72 parts collector,…
Re: Will 3/4-ton lower control arm shaft work for 1/2 ton?
What year truck are you working on?
This info is available online,... but the correct year would be helpful.
04-16-2012, 12:31 PM | #3 |
Salty Sailor
the shafts do not interchange, you need 1/2 ton shafts
86 c-10 Custom Deluxe Savannah, Georgia |
04-16-2012, 01:52 PM | #4 |
Active Member
alright, well I guess I will have to order new shafts as well. thanks guys.
lolife99, it is the truck in my signature (sorry for not clarifying)
