Rear end?
I have a 72 c20 and i was changing my rear brakes and noticed my rear end is only a 10 bolt im used to a 3/4 ton having a 14 bolt is this normal?
Posted via Mobile Device |
Re: Rear end?
My C-20 Dana 60 has 10 bolts on it's cover.
Re: Rear end?
Another ? I had was why does my rear end which i know is stock look so much like a ford 9 inch?
What?
Re: Rear end?
It's an Eaton H052
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Re: Rear end?
Same as mine, these suckers are strong! I can still see the machine marks on mine.
1969 Chevy c20(Miss Hackjob) |
Re: Rear end?
Yeah its definately tough just a pain to work on, but thanks for your answers
Re: Rear end?
Another question, is there any way to know the gear ratio on my rear end without counting the teeth? There is no tag on my rear end ive looked? Its apparently an eaton h052 according to the guy above
The Niner
![]() Join Date: Nov 2010
Re: Rear end?
Usually 4.10's, 4.56's or (gulp) 5.13's
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
Re: Rear end?
Id say 4:10 then because i can run hwy speeds it just keeps it cranked up pretty good but im not sure
Re: Rear end?
I've got one with 5.13's. Screams on the freeway and sucks gas faster than you can put it in!
'67 C20 LBW |
Re: Rear end?
| Bookmarks |
