Old 04-12-2012, 05:23 PM   #1
84_chevy
2 Questions
Can the gasket for the oil pan be replaced with the engine in the truck, it's an 84 4X4
second question; where can I find the serial number on the block, its a 350 and it really dirty, cant seem to find the numbers anywhere.
84_chevy is offline   Reply With Quote
Old 04-12-2012, 05:26 PM   #2
thesickc10
Re: 2 Questions
in response to your second question the casting number is behind the passenger side head on the block
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 04-12-2012, 08:05 PM   #3
84_chevy
Re: 2 Questions
Can I see the number from the top down or will I need a mirror or something to look for it at the back of the block
Old 04-12-2012, 08:30 PM   #4
thesickc10
Re: 2 Questions
youll be able to see it on top. might be lost under a lot of grease and dirt so poke around a little bit
Old 04-12-2012, 08:42 PM   #5
bilfman
bilfman's Avatar
Re: 2 Questions
You can change the gasket with the vehicle in the truck. Depending on clearance you may not be able to take the pan out and will just have to work with it there having a few inches of clearance. Keep in mind that there is a rubber seal on the top and bottom of the crank. Most peeps just change the bottom rubbers in the pan and pan gasket. That said you can remove the top seals. Removing and pulling in the top seal can be done with the motor in the vehicle and not taking out the crank, this is done by pulling it out with a hook type tool and pulling in the new one with a wire fished through and attached to the new seal. You can modify the tab a bit on the side of the seal being pulled through to make the pull easier and also use lube.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-12-2012, 11:01 PM   #6
84_chevy
Re: 2 Questions
I watched a vid on you tube of a guy changing the gasket but he had the motor out of the truck and upside down. I'm sure that's the easiest way to do the job but not very practical for me.
He used a 4 part gasket, the 2 rubber thingies that go over the crank shaft end a the 2 cork thingies that go along the oil pan sides. are you referring to the 2 rubber thingies or are there other gaskets deeper inside that I don't know about?
Old 04-12-2012, 11:25 PM   #7
bilfman
bilfman's Avatar
Re: 2 Questions
I am referring to the rubber thingys
Old 04-16-2012, 04:36 PM   #8
hartbraker
Re: 2 Questions
One piece gaskets have been referred to me. If you're gonna take the time to tear it down like that... might as well buy the best gasket you can, because they are a pain in the butt to do with the motor still in the truck. Make sure you use rtv in the front and rear of the pan where the "u-shaped" part of the pan is. Good luck
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 04-17-2012, 07:32 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 2 Questions
down behind the end of the valve cover
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
