04-12-2012, 06:24 PM | #1 |
04 no intermitent no crank
Hi, I'm having a problem with an 04 chevy 3500 6.0l. What it is doing, is occasionally it will not crank. the first time it wouldn't start I was at a store, when I went to start it no crank but I could hear a relay trip. after a bit of searching i found the three matching relays under the hood. I played musical relays. the truck fired right up I ordered new relays for those positions. everything worked great for three days and today it did it again. I haven't done much in the way of diagnostics yet, but I'm looking for ideas of where to start looking.
04-12-2012, 08:14 PM | #2 |
Re: 04 no intermitent no crank
Next time it happens, tap on the starter, If it starts....Replace starter....The brushes are wore out.
04-12-2012, 08:40 PM | #3 |
He's got mean nasty FANGS!
There is a known problem with the Ignition 1 relay dropping voltage causing a no start. They make a heavier duty relay to go in its place. Moving the relays around you could have moved the bad one to a location where it won't rear its ugly head.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
