Old 04-12-2012, 06:39 PM   #1
jhngardner367
jhngardner367's Avatar
gauges/'85lwb
I've had several Chevy/GMC trucks in my life,and I've noticed that the gauges like to stop working,at times,and if you tap the front,they work,again!
This is irritating as all get out,and I think I,ve found the reason. The contact clips,where the gauges attach,get weak,and lose contact. I cured mine,by pulling the cluster,and putting tension on them,with small o-rings,over the 2 prongs that the gauge pins slide through.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
