Old 04-12-2012, 08:45 PM   #1
Dustytrix
1992 fuel fittings
Can someone tell me exactly which fitting I need to adapt the corvette filter into my fuel lines? I have an 04 5.3 that I will be installing into my 92 silverado that has a 5.7 tbi engine. I know the pump needs to be ep-381 and the filter wix 33737. But the fittings to adapt the filter into existing lines and to tie into the fuel rail keep confusing me, please let me know what you can so I can order this stuff. Thanks Randy
Dustytrix is offline   Reply With Quote
Old 04-13-2012, 06:52 PM   #2
Dustytrix
Re: 1992 fuel fittings
I still couldn't find any info to connect my existing lines,to the corvette filter, does anyone think it would be ok to just cut the existing lines and use some efi hose?
Old 04-14-2012, 12:04 AM   #3
Lower
Lower's Avatar
http://www.summitracing.com/parts/RUS-640860/
http://www.summitracing.com/parts/RUS-640850/
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 04-14-2012, 11:05 AM   #4
Dustytrix
Thanks Lower those look like the would fit at the fuel rail, which I can use at the engine. Do you have any idea what I need at the filter?
Old 04-14-2012, 12:14 PM   #5
nacho55
It should work on the regulator, also russell has an updated part number for the adapters make sure you get those that have a threaded locking clip instead of the plastic ones, unless you drill and safety wire them they can pull off easy after the clips get older. Mine would pull off by hand
nacho55 is offline   Reply With Quote
Old 04-14-2012, 03:02 PM   #6
Dustytrix
Thanks again guys so Nacho you are saying they will work at the filter and the intake? I think the supply is 3/8 so I will need 2- 3/8 and one 5/16?
