Old 04-13-2012, 07:54 AM   #1
amrva
4" lift question
I found someone selling a 4" suspension lift kit came off an 86 4x4 full size pickup. I'm wanting to buy it but wasn't sure if it would fit my 89 suburban, anyone know if its compatible?
amrva is offline   Reply With Quote
Old 04-17-2012, 11:14 PM   #2
BlackhillsHD
BlackhillsHD's Avatar
Re: 4" lift question
Yes it should be the same. Just make sure that you get the steering arm and shocks to go along with the lift, as you will need both.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44
1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt
General Motors Master Certified wrench swinger
ASE certified Master auto tech
Instructor of Automotive Technology
BlackhillsHD is offline   Reply With Quote
Old 04-19-2012, 06:44 AM   #3
JPalmer81
JPalmer81's Avatar
Is your suburban and the truck it came off of rated at the same GVW? i.e. 1/2 ton 3/4 ton 1 ton? Make sure that is the same also.
1988 Chevy Crew Cab 1ton 4x4 SRW LWB
1977 Dodge 1 ton 4x4
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=516872
"The price of Freedom is Eternal Vigilance"
JPalmer81 is offline   Reply With Quote
Old 04-29-2012, 05:47 AM   #4
Mudder
Mudder's Avatar
There were two lengths of rear springs if I'm not mistaken.
Mudder is offline   Reply With Quote
Old 04-29-2012, 09:43 AM   #5
Mike C
Mike C's Avatar
Yup. If the lift is all spring, make sure they rears are same length eye to eye. Most likely your Suburban is 56", but the truck could be 52" or 56" depending on options.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-29-2012, 12:24 PM   #6
rayfinseats
Watch your front drive shaft. I just went +2" and mine rubs the crossmember.
rayfinseats is offline   Reply With Quote
Old 04-29-2012, 05:07 PM   #7
x ReAcT x
Oh i didnt even think about that, i just spent big money on a BDS 4" lift and still waiting to install it. If your rubbing with a 2" i can only imagine what mine will do. what is a remidy to get rid of the rubbing? drop the tansfer case?
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 04-30-2012, 12:51 AM   #8
rayfinseats
On mine it barely touches the crossmember in one spot. It sounds like hell but I think I'll just grind the crossmember a bit. My front driveshaft could be just a hair shorter too. I have a TH350 with a NP208. You may not have a problem just something to keep in mind.
Old 04-30-2012, 01:31 AM   #9
Mr. 250r
Mr. 250r's Avatar
Assuming it is all spring then the gvw would make a difference unless your looking to get a slightly better ride, but like most lifts that small it's just a block in the rear so it wouldn't matter. Aside from that i have a 4in block lift and my transfer case was dropped from the factory pieces *the little 1in spacers sitting on top of the crossmember* and didn't rub i then put them back up top like original as i had to tilt my whole engine assembly forward for the 6.0 swap and the driveshaft is still fine and even when its on a lift suspension fully sagging the driveshaft was almost hitting the exhaust but not the crossmember spacers or not
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 04-30-2012, 09:24 PM   #10
Suburbans used 56" rear springs. There's a nice pair of 4" EZ-Rides for sale on the parts board.
I've never had any problems with front drive shafts rubbing cross members.
