Lowering and C-notch
Has any one lowered their 71-72 rear with a 4" coil and not used a c-notch. I know all the books and manufactures recommend a notch when lowering 4 or more but I was wondering if it is just a ploy to get you to buy more. Right now I am measuring 6" between the bottom of my bump stop and top of my axle so if I lower 4" I should have 2" of play. Would that be enough for travel without having the bump stops slam the axle? Also this may be a stupid question but is there a way to tell if your coils are stock or not? I would be really mad if I ordered a 3" coil and installed it only to see the truck drop 1"
Re: Lowering and C-notch
Purchase the 4 and c notch ,2 inches the rear end will still hit the frame .
Posted via Mobile Device |
C-10 Club Member
No need for a notch at 4".
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
What Cole said...
And you can cut your bump stops in half for a little more room... Dano
![]() ![]() It ain't yours, if you didn't build it! |
///Relaxed Atmosphere
i got 6 inch coils and a 1/2 inch block with no c-notch so a very well doubt you will need to c-notch with a 4 inch coil
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
no need for a cnotch for anything under 6 inches of drop. I had six inch drop springs with no notch and it barely if ever bottomed out.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
wanna be 67
^ what they said. I have 6" without a notch.
Shortbed club member
Ditto
6" drop here with no notch, just cut your bump stops back.
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
#9 | |
VA72C10
![]() Join Date: Mar 2008
Measure on a flat surface from the ground to the wheel arch front and rear. That will give you a starting point. You can compare it to some finished rides on here. Post here to get some other input/comparisons... Most of the time stock springs have sagged at least an inch...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
rear well to ground 34" and front well to ground 32"
68 C 10
![]() Join Date: Aug 2010
Im going with a notch in mine only because im going with 6 to 7 inch drop . If i was only going 4 i would leave it alone.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
