04-13-2012, 03:20 PM | #1 |
need pic of front draglink and tierods asap!
Something seems wrong with my 64.
I need a good pic of how close the draglink? Or whatever the bar that crosses left to right between tierods. Mine is so close to crossmember and drivers inner tierod damn near touches cm when turning wheels Posted via Mobile Device
Tim Road Hounds |
04-13-2012, 03:30 PM | #2 |
Re: need pic of front draglink and tierods asap!
Here's pics. Something seems very wrong. The drivers inner tierod actually has been grinding into cm.
Tim Road Hounds |
04-13-2012, 03:42 PM | #3 |
It's Better With Nitro
Mine is pretty close, but stays within the notched area of the crossmember...
04-13-2012, 03:43 PM | #4 |
1962 C-10
I don't have a pic on hand, but our '65 seems the same way. Dam close.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
04-13-2012, 03:48 PM | #5 |
What about the drvrs inner tierod? Mine has actually made gouge marks on cm. Soon as wheels are straight or turned right its touching cm
Tim Road Hounds |
04-13-2012, 03:51 PM | #6 |
Best pic I could get of it
Tim Road Hounds |
04-13-2012, 03:56 PM | #7 |
This seems to be a very popular thread topic since one was started a few weeks ago about installing PS adapter brackets. Several threads about it. Converted to R & P-no concerns with clearance here.
04-13-2012, 04:00 PM | #8 |
I'm not installing ps brackets or RnP....so how does that reply help me?
I'm laying under truck now. That's why I asked for help asap while I'm staring at it. Posted via Mobile Device
Tim Road Hounds |
04-13-2012, 07:03 PM | #9 |
That must be common, my 64 is the same way.
Friends don't let friends drive Fords |
04-13-2012, 09:31 PM | #10 |
For me, the center link is close... but there's enough room that it clears. Right now there's no weight on the front, but there's no indications that the tie rods have hit.
Bryan (Redneck) '66 Chevy Longbed Fleetside '12 Dodge Ram 3500 '08 BigDog Pitbull '11 Cargomate Trailer (Toy Hauler) |
04-13-2012, 10:38 PM | #11 |
I've stared at the damm thing for hours while doing front airride stuff.
Can't see anything that looks wrong...it just seems like it looks wrong...in my head. Not sure what's deal with the drivrs inner tierod rubbing cm, but for now I clearanced at small spot on lip of cm so it doesn't rub. I'll sort it out later. But the airride is done... Posted via Mobile Device
Tim Road Hounds |
04-15-2012, 04:27 PM | #12 |
no camera handy but my 63 has enough clearance to slip your fingers between the drag link and cross member also your closest point should be when the wheels are straight ahead and should move away as the link moves on its natural arc
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
