Old 04-14-2012, 01:46 AM   #1
tdkosta
tdkosta's Avatar
AA overdive on craigslist
Wish I had the money for it and it were in town.
http://denver.craigslist.org/pts/2916111348.html
tdkosta is offline   Reply With Quote
Old 04-14-2012, 01:48 AM   #2
tdkosta
tdkosta's Avatar
Re: AA overdive on craigslist
Correction it's a Gear Vendors overdrive.
Old 04-14-2012, 09:06 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Those things are AWEsome... and bulletproof. SO much better than an overdrive tranny.
Tom Vogel is offline   Reply With Quote
Old 04-14-2012, 09:16 AM   #4
Big Block
Big Block
Big Block's Avatar
Looks like a sweet deal.
Big Block is offline   Reply With Quote
Old 04-14-2012, 12:18 PM   #5
BOHICA
BOHICA's Avatar
Good find!
I admit I've never understood why someone would buy one of these new. For the money, you can install a nice OD transmission and probably still have some left over.
1954 Ford F-100
1956 Chevy big window
1970 4x4 Blazer CST
1987 Land Cruiser
1990 Chevy K3500 454
BOHICA is offline   Reply With Quote
Old 04-14-2012, 01:12 PM   #6
Ole Beater
What kind of crazy drive shaft angle would you need to work with that. And how short.
Ole Beater is offline   Reply With Quote
Old 04-14-2012, 10:25 PM   #7
Bigb401
Can someone explain when this would be used and what is different than an overdrive transmission? Is this for a four wheel drive trucks also?
Proud to be IBEW Local 2150
Bigb401 is offline   Reply With Quote
Old 04-16-2012, 01:32 PM   #8
cleszkie
cleszkie's Avatar
I found one in my local Ecology Pick and Pull and bought the entire set up fopr $100 (including all electronics). Got the right adapter to fit my NP205 off ebay, rotated my rear axle spring perches, had a new slip yoke CV driveshaft made and bolted all in. Best mod I ever made. Its been working hard for three years now without a hitch. A lot of people thought the Blazer was too short to install it without a crazy driveline angle, but it worked out just fine, even with the bigger 14 bolt rear center section.
It should be noted that the pics were taken with a bit of droop, so the angle is even flatter than it appears. I also run a 6 inch lift.
cleszkie is offline   Reply With Quote
Old 04-16-2012, 06:09 PM   #9
Ole Beater
Nice.
