Old 04-14-2012, 08:56 AM   #1
76stepsidechevy
1" steel pucks at body mounts
Are these round pucks stock? I thought it was a body lift at first but my bumpers are still bolted to the frame and line up with the body. The truck is a 76 k10.
76stepsidechevy is offline   Reply With Quote
Old 04-14-2012, 04:51 PM   #2
bigwheel15
bigwheel15's Avatar
Re: 1" steel pucks at body mounts
Im pretty sure they arent stock, they should be made of rubber.
bigwheel15 is offline   Reply With Quote
Old 04-14-2012, 05:37 PM   #3
maskale
yeah you should have rubber and then a metal puck if it does have a lift.
maskale is offline   Reply With Quote
Old 04-14-2012, 07:49 PM   #4
76stepsidechevy
I have both rubber and metal but not all of the mounts have the metal pucks which is why im confused. The radiator support mounts and the rear most bed mounts dont have the pucks.
Old 04-14-2012, 08:08 PM   #5
bilfman
bilfman's Avatar
Metal is defintely not stock. Metal is actually a very poor body mount. Body mounts should always be made of a medium that absorb shock and sound. Most are poly, rubber or rubber compound. A metal mount will transfer sound and vibration into the vehicle. The purpose of a mount is to create a barrier for sound and vibration or at least the ability to absorb some of it
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-14-2012, 08:12 PM   #6
76stepsidechevy
Yea these are stacked with the rubber bushings like a body lift would be but just not at all the mounts.
